Author Topic: Dad's 1978 Honda CB550k  (Read 37455 times)
Offline joegeis
  • '78 Honda CB550k
Re: Dad's 1978 Honda CB550k
« Reply #400 on: August 25, 2025, 06:46:24 PM »
Looking good!
Is that oil JASO MA2 rated?
If not, you may have a slipping clutch.
No, its actually not. I bought it a while ago, and for the life of me I can't remember why I picked this one.
That said, I went with it for now. I got the exhaust back on and fired it up! It started on the first crank with the choke on, and idled pretty evenly shortly after. I took a couple of videos, and I do hear some unusual engine noise that I'm hoping you guys can help me with.
Videos at the bottom:
https://photos.app.goo.gl/76NLUK6LhMfKbXkt9
« Reply #401 on: August 25, 2025, 07:33:33 PM »
It sounds like the cam chain is a little bit loose?
Maybe try this: remove the #4 intake valve's tappet cover (and the points cover) and slowly turn the engine (forward) at the points' nut until the intake valve starts going down, then about 15-30 degrees more. Right there, release the nut of the cam chain's tensioner, and you might have to wiggle the slotted screw a few degrees side-to-side (in case it's stuck). This releases the spring tensioner against the tensioner bow, and the slack of the chain will be on the back side right then. Then snug the nut back down & see if it helped?
How close to perfect is the ignition timing? It should be dead-on both of the "F" marks at engine speeds below 1200 RPM.
Offline joegeis
  • '78 Honda CB550k
« Reply #402 on: August 25, 2025, 09:03:38 PM »
Good points! I did not set ignition timing after the rebuild, so that is likely not perfect.
I tried to set cam chain tension, though I always feel like it doesn't actually do anything. The adjustment bolt always wants to turn with the locknut when I try and tighten it. I'll need to spend more time monkeying with this I think.
« Reply #403 on: August 25, 2025, 09:11:14 PM »
It never does. ;) Don't force anything or fix it until it's broke. ;D
Offline joegeis
  • '78 Honda CB550k
« Reply #404 on: August 26, 2025, 07:25:09 PM »
I figured out that horrible sound tonight. I was missing a washer on the cam chain tensioner, so I was not able to get the nut tight. Whenever I tried to tighten it, all I was doing was turning the adjustment bolt the wrong way. I figured it out, added the missing washer, adjusted the cam chain and tightened it all down, and it sounds so much better now!
I decided to push my luck right before coming in for the evening, and got the timing strobe light out and hooked up to cylinder 1. With engine idling at about 1400 rpm, the dash mark was lining up over the "F" on "TF 1.4." WAY further out from the dash line for "T." I have Hondaman's transistorized ignition, if that effects timing. I don't have a reason for thinking that my timing is incorrect, just thought it prudent after the rebuild and before syncing the carbs (tomorrow's job).
Once that's done, I think its time to throw the tank on and go for a test ride :)
Offline denward17
« Reply #405 on: August 26, 2025, 07:46:39 PM »
Did you check 2-3 ?
Offline joegeis
  • '78 Honda CB550k
« Reply #406 on: August 29, 2025, 07:02:18 PM »
I did not check 2-3 yet. I actually decided to just throw the seat on and take the test ride I had been dying for! Got around the block and the bike died before I realized I forgot to open the petcock! That was a scare :)
When I went out today to take it for a little longer ride, the #3 carb was leaking fuel. I gave it a rap with the screwdriver and couldn't get it to stop, so I tore the carbs out again. I've inspected the floats and the float valve. There was no debris in there and nothing bound up. I blew everything out with compressed air. I'm not really sure what else it could have been. I have not had overflow/leaking problems before. Tomorrow I'll hook it up to my aux tank and see if it starts overflowing again before I start the painful process of reinstalling the carbs. I'll report back if it's leaking still.
Other things:
1. I tried syncing the carbs with vacuum gauges (before I was having my leaking problem). I admittedly have no damn clue how to do this properly. I chased them around and around and think I only made it worse. It seems like nothing I do can change the reading on carb 4, only cause the others to increase dramatically and rev the bike up. I put it back to how it was when I started. I did confirm that my idle mix screws were all set to 1.5 turns out before starting.
2. Because of my sync issues, I think I should return to my timing issues first. Another area I feel woefully ignorant. I have Hondaman's transistor ignition, so I don't think I can do static timing anymore, right? I was getting no light when trying that way. I do have a dynamic strobe gun, but the index line seemed way out in front of where it should be on 1-4. Again, I'll try to get some pictures of it next time.
I'm taking the Triumph to the track again this Sunday, so that bike needs some love tomorrow!
Offline joegeis
  • '78 Honda CB550k
« Reply #407 on: August 30, 2025, 12:17:08 PM »
Got the carbs back on with no leaks! I took it for a 10 min test ride around the neighborhood. It's feeling really good now. I have a few things to work on still, but its definitely rideable now. If you look closely, you can see me almost forget to turn the petcock on again!
To Do List:
* Fix hanging Idle (timing, tuning?)
* Replace missing nuts for the speedo and tach
* Fix/replace misreading tach
* Replace petcock and get rid of in line fuel filter (ordered)
* Replace fenders and tail light (someday).
Pretty short list considering how far we've come! Okay, time to start track prepping the Street Tiple!
« Last Edit: August 30, 2025, 12:18:45 PM by joegeis »
« Reply #408 on: August 30, 2025, 12:28:59 PM »
That's where it's supposed to be, at the F mark: F for fire. The T is for Top Dead Center.
Offline joegeis
  • '78 Honda CB550k
« Reply #409 on: August 30, 2025, 04:01:53 PM »
I marked in this picture where it lines up. Is this right? Not over that second line, but over the letter F itself.
Also, I just punctured a hole in the oil pan of my Triumph Street Triple while loading it on the trailer for the track tomorrow... Although I won't be racing tomorrow (I'm fresh out of oil pans), at least I have the CB running while the other bike is in the shop for the next week or two!
« Reply #410 on: August 30, 2025, 04:37:05 PM »
The engine should fire on the small,stamped line just to the right of the T,which represents the F mark on that particular advance mechanism.
I think you have the bike firing way too advanced if it fires on the red mark
« Reply #411 on: August 30, 2025, 08:55:43 PM »
I keep forgetting how close the T and F marks are on a 550 compared to a 400 or 750. :-[
Offline joegeis
  • '78 Honda CB550k
« Reply #412 on: September 01, 2025, 08:35:24 AM »
Okay, uncovered more clues (and problems) this morning. I was trying to work on timing, but I couldn't get the bike to idle below 2k rpm. It would just die. I decided to check exhaust temps using an IR thermometer. 1-3 were 160 degrees. #4 was 90 degrees. #4 isn't firing. I tested resistance at the coils and between the 1-4 spark plug wires, and they look good. So I tested for spark with all 4 wires using the plug from #4. All wires gave strong spark, except #4. I got only a little orange spark and usually only when first pressing or while releasing the start button. If the coils, wires and caps are all new, and resistance is good, what else could be causing this issue?
Background:
New Coils PartsNmore 17-6823
New Caps PartsnMore 23-3119
Hondaman Transistorized Ignition
Two year old battery, but always kept on a tender
Its starting to feel like my gremlins are electrical and not air/fuel. Also, not sure if this is normal, but when trying to set the timing, I noticed sparks between metal parts under the points cover. You can see them in at the beginning of the video at the bottom of this album.
I'm going to let the battery juice up for a bit, then maybe try removing the transistorized ignition, or even putting the original coils back on the bike. I'm not really sure where to go from here...
« Last Edit: September 01, 2025, 08:57:51 AM by joegeis »
« Reply #413 on: September 01, 2025, 09:28:58 AM »
What does the #4 spark plug look like?
Offline joegeis
  • '78 Honda CB550k
« Reply #414 on: September 01, 2025, 09:46:56 AM »
brand new - only a few miles on it.
« Reply #415 on: September 01, 2025, 09:56:52 AM »
I would try putting the old 1-4 coil back on and see if that helps.
Offline denward17
« Reply #416 on: September 01, 2025, 10:07:13 AM »
Looking at the video, its hard to tell, but are the green/yellow wires connection point touching the base of the points plate?
I saw the sparks near the wires....is it grounding out?
Offline joegeis
  • '78 Honda CB550k
« Reply #417 on: September 01, 2025, 10:30:08 AM »
So I think maybe I've started going down too many paths.
I tested voltage on the black/white wire going to the coils and it was only 10.45 V. I hooked up to the tender and I'm charging the battery. I've been doing a lot of testing and idling, so the battery may need a charge.
I also unplugged the transistorized ignition system and plugged the points back into the coils directly. I'm getting spark at #4 now (but I didn't retest after charging the battery back up before taking off the transistorized ignition!) THEN, I ran the carbs dry (did not hook up a fuel source), so inconclusive test.
So, I'm going to take a lunch break, let the battery charge, hook up my aux fuel tank, and then test #4 for spark, and then try to get it idling properly, then try to set timing off the points, then plug the transistorized ignition back in and see if it is still all working.
I went through every connector on this bike and cleaned/lubed them up two years ago, though I think I've always been dealing with resistance through the old harness. If none of this gets it running just right, is my next step a new harness?
« Reply #418 on: September 01, 2025, 12:03:46 PM »
Maybe a new battery first?
Offline joegeis
  • '78 Honda CB550k
« Reply #419 on: September 01, 2025, 12:22:03 PM »
I'm moving this troubleshooting over to a new thread in the normal forum: http://forums.sohc4.net/index.php/topic,205739.0.html
Offline joegeis
  • '78 Honda CB550k
« Reply #420 on: September 16, 2025, 08:34:24 PM »
I finally got my new OEM boots and clamps in the mail. I installed those, cleaned up my bench sync (it was close, but had to lower the slides slightly). I also added the in tank fuel filter and removed the inline filter and replaced last year's gas with fresh. The bike is running so much better now! It started right up, and after running with choke for 20 seconds, it came down to a nice and steady 1100 rpm idle. All cylinders were reading the same exhaust temp, and the throttle was responsive. I sprayed starting fluid around the boots and there was no response, so my leak is gone! I'm going to ride it to the office tomorrow and see how it does. I'll give the carbs a real vacuum sync in the next few days as well.
Otherwise, it seems like I'm back in business and have no more major issues. Thanks for all the help getting this figured out!
I'll post some pictures with it all cleanup up soon. If my issue really is gone, I'll probably just enjoy it as is the rest of the season. I'll come back to worrying about cosmetic things or "upgrades" down the road. It's time to finally get some miles on this thing.
Offline joegeis
  • '78 Honda CB550k
« Reply #421 on: September 18, 2025, 02:13:58 PM »
I hooked up the vacuum gauge this morning and made a couple of tweaks to the sync. I think I moved the #1 and #4 screws about 1/8 turn each, so it was REALLY close off the bench. Then I put about 50 miles on the bike. Overall it ran well. Throttle was smooth and responsive and it pulled decently up to about 7k RPM (I didn't push it any further than that yet). The only thing I noticed is that once the engine was good and hot, it idles at 2k rpm when coming to a stoplight. If I fiddle with the idle screw, it will drop back down to 1100, but it will want to to die or it will die when I come to the next stop. I just left it alone eventually and let the bike idle at 2k when stopped.
Also, somehow my choke is no longer working. It worked last night (bike would fire up and run at 4k rpm for 10-20 seconds). However this morning (before doing the sync) the choke had minimal if any difference on rpm. I can see the linkage is connected, and the lever moves up and down, but its not having any impact!
Also my tach gets stuck at 4k rpms and take a good thump to unstick and start working again. I suppose I need to get that taken apart and cleaned!
« Reply #422 on: September 21, 2025, 06:56:18 PM »
The 1978 550K has real "touchy" carbs, and they run lean at idle (for emissions reasons). This, combined with the too-soft springs in the spark advancer, tend to make this particular 550K want to idle high, or not at all, when it is warmed up. Part of this today is caused by modern gasolines, which burn much slower than 1970 fuels, and when some unburned gas wets the intake tubes the heat of the engine vaporizes it and causes the engine's idle to tend to wander about 1500 RPM from your desired point - either up, or down (as, in, stops).
The first "cure" I've always had to apply to this particular 550K3 is the same one I use with the 750K8, as it suffers similar issues: slow down the spark advancer by tightening the springs. This normally involves clipping off at least 1/2 turn form each spring as a start: alternately 1 full turn off 1 spring, which yields the same result. The general idea is to slow down the spark advancer: it is rushing to full advance now around 1500-1600 RPM, which, since it is close to idle openings of the slides, makes the advancer stay there when the idle won't slow down. I can't think of a single 550 that I have seen in the past 15 years that DIDN'T need this fix in order to idle at all here in Colorado, where the high altitude makes this a really big problem for the bike. I watched a nearly new (4000 miles) 550K3 sell for $250 on Craigslist here because the owner noted in the listing: idles at high RPM, have not been able to fix it". That was 5 years ago, I think, and was one of the reasons I started on the 500/550 book.
It's the same story here for the 750K8 and most of the 750K7 bikes I've worked on, too. Even the earlier ones benefit, especially here, from slowing down the advancer to more closely match modern fuel burn rates. My 750 returned to its normal happy low-speed self after I made it reach full advance at 3300 RPM instead of the OEM 2500, which by 2005 had become 1800 RPM with the original springs becoming heat-softened. Now I do it to every SOHC4 that shows up here, and every rider likes it afterward.
The characteristic symptom of too-soft springs is: when cold, it will idle. When hot, if the engine is coaxed down to idle speed, it will idle. If the throttle is blipped open when hot, most of the time it will not settle to idle, but hang around 1500-1800 RPM, depending on which type of gas, carbs, and pipes it has. Real soft springs will make it hang even higher, like 2500 RPM.
Offline joegeis
  • '78 Honda CB550k
« Reply #423 on: September 21, 2025, 08:17:31 PM »
Thanks Mark! This probably was definitely worse when I first started working on a the bike 2 years ago. If I remember right, I bought some new springs (purchased an aftermarket spark advancer, but just stole the springs from it, which were definitely tighter than my OEM springs. I don't think I shortened them at all. What you are describing is exactly the behavior I'm seeing, so I'll investigate my springs further.
Today I did a little paint correction on the tank and side covers. I washed, applied a clay bar, then a gentle cutting and polishing compound followed by a spray on ceramic coating. It's far from perfect, but I was able to get rid of much of fog/haze on the tank. Next up is the aluminum covers, which I'm going to polish up with scotchbrite to a brushed finish. I do not want to shine them, but would like to start removing some of the oxidation and staining, as well as paint in black around the "HONDA" emboss. These covers have not come off the bike yet and the screws were not giving up easily, so I decided to save it for another day and took the bike for a ride instead.
On my way back, I hit a bit of a pothole, nothing crazy, and started hearing a rubbing noise. When I got back to the garage, I found that bolt holding on the left shock is now rubbing against the bolts of the wheel hub! I have no idea how going over a pothole could have possibly caused either of these to move out of position. Everything is still tight, so it does not make sense to me!
Some glamor shots
« Reply #424 on: September 21, 2025, 09:36:45 PM »
Some glamor shots
Check your swingarm bushings;they may be wobbly and worn out.
