Moving from my
build thread here for more visibility.
I'm working on tuning the bike after a top end rebuild. The bike starts up easily when cold with choke, but will die if idle speed drops below 2k rpm, even when warm. Exhaust manifold is ~160 degrees for #1-3, but ~90 degrees on cylinder 4. I have new coils, wires, caps and plugs. Carbs were recently cleaned. Battery is 2 years old AGM, and typically on a tender.
Facts:
Battery voltage 12.9
Voltage on the blk/wht wire at the coils: 10.4
Coil primary resistance: 0.8-0.9 (with the setting on the "20")
Coil secondary resistance (no caps): 16.6 ("20k")
Cap resistance: 4.8 ("20k")
What I've done so far:
1. Disconnected my Hondaman transisitor ignition and plugged points back in to coils directly.
2. Tested for spark - I think it seems weak, but there is spark. You can see some videos I took at the bottom of the
album here.
Two years ago I went through all the electrical on this bike, cleaning up and lubing connections, so although it's not perfect, the wiring should be in decent shape.
Next steps:
1. Try starting again and then check plug for wetness
2. Compression test
What else am I missing? I'm at a loss.
update -
Below is a picture of the #4 plug. It was wet when pulling it out after starting up the bike for a minute.
I also did a compression test - the first one after the top end rebuild. The engine isn't fully warm right now. I tested with both throttle closed and wide open (WFO)
#1: 120 closed 150 WFO
#2: 90 closed 138 WFO
#3: 90 closed 120 WFO
#4: 150 closed 150 WFO
So, thats really strange. I don't know if it has to do with the engine not being properly warmed up or if I didn't test it well, or if the rings are well seated yet (literally has ~30 minutes of running time since putting it back together). Maybe I'm going down the wrong rabbit hole.
Seems 1 is rich and 2-3 are lean. Doubt that has anything to do with my issue though?
