Author Topic: Does Yamiya/Yamiha?? have a website ??  (Read 1214 times)
« on: June 26, 2023, 03:13:48 PM »
 The place in the UK? that gets motorcycle parts from Japan for our cycles.. Does anyone know their correct name/web address ?
Re: Does Yamiya/Yamiha?? have a website ??
« Reply #1 on: June 26, 2023, 03:46:26 PM »
Yamiya is a Japanese company, are you looking for CMSNL?
« Reply #2 on: June 26, 2023, 04:12:54 PM »
Oh,I thought Yamiya was a separate contractor in the UK that sells OEM quality parts:like a direct distributor for the Japanese companies??
« Reply #3 on: June 26, 2023, 04:25:16 PM »
David Silver Spares? DSS?  They are a UK purveyor of Honda parts…
CMS is Dutch, in Netherlands…
DSS has an American office too.
« Last Edit: June 26, 2023, 04:26:49 PM by RAFster122s »
« Reply #4 on: June 26, 2023, 04:28:05 PM »
David,have you ever purchased from wemoto.com ?
« Reply #7 on: June 26, 2023, 09:29:35 PM »
Once before years ago, they had some parts I couldn’t find from any US sellers for a bike more popular in England than here. Stuff I got was OK, better quality than most stuff from 4 into 1. I’ve had 2 orders from 4 into 1 and after looking at the quality of the things I got from them I’ve sworn those were my last orders from them.
« Reply #8 on: June 27, 2023, 12:26:10 AM »
Another seller was Kenosha_kid.
Think located in UK, sold CB750 and Kawasaki (Z1-900 parts)
Some parts as Yamiya750.com sold.
« Reply #9 on: June 27, 2023, 04:25:53 AM »
I agree with you David about not wanting to get anything again from 4into1. They are a Chinese owned and run outfit with a warehouse in California. You can't even contact them by phone when there's a problem with their products.
« Last Edit: June 27, 2023, 04:27:32 AM by newday777 »
« Reply #10 on: June 27, 2023, 06:20:23 PM »
 I got a pair of 4 into1 K0 rear turn signal ears during covid. Last night I noticed the left one has a tube loose from the bracket.
« Reply #11 on: June 27, 2023, 10:31:00 PM »
I tried their pilot jets to CB750. Size 42.5.
They were a little tight.
Engine ran bad so I removed them.
Found that 2 of them were broken, the thinner bottom part stucked in the carbs.
I had to remove carbs and drill the brass residues away.
2.0mm drill removed it. I drilled all carbs to be sure they will be equal. It might have taken a very little alu from carbs.
Measured the depth, tape on drill to mark where to stop.
Old stock 40 went back in.
« Reply #12 on: June 28, 2023, 01:16:00 PM »
PeWe’s note reminded me of a later style set of rear turn signals and stalks I ordered from 4-1. Very inexpensive and they looked OK, but didn’t work. Took a while to see the ground eyelet had been pinned to the base, that was powder coated. So poorly done, there was ZERO connectivity! Both stalks…..
