« Reply #9 on: September 08, 2023, 02:07:18 AM »
Most PDR guys will probably say that the metal is too thick to massage the dents out, good body guys will say they can spot weld dent puller pins on and pull the dents mostly out, then filler to smooth it out before repaint.
Speaking from personal experience, that is completely untrue. I have fixed dozens of these vintage tanks by PDR. I have also cut and welded them back together. The latter is far more work and the results are equal.
As I said, MOST WILL PROBABLY SAY. All I did was to state the facts.
How can you say it COMPLETELY UNTRUE?
You may have the experience to make it happen, but there are lots of PDR shops that don't.
Logged
Stu
My current rides
Prior bikes....
