Author Topic: 750F1 Pad & piston jammed on front brake  (Read 1971 times)
Offline Rnobx67
  • "failure is an option here."
« on: October 15, 2023, 11:42:07 AM »
Hi guys. I am trying to repair the front brake on a F1 '75 that was stocked with no fluid since.... at least 7 years. first I put some DOT3 in the reservoir.. nothing happened, the master cylinder is stuck. so I disassembled everything, and order rebuild kits for master and brake caliper.
I got success with the pad on the side without the piston and the master cylinder is not jammed anymore (I didn't remove a thing except the lever) with help of wd40.
But the pad and the piston on the other part is not going anywhere.
 I let fine oil, or wd 40 stay in the cavity but there is still no move.
Re: 750F1 Pad & piston jammed on front brake
« Reply #1 on: October 15, 2023, 11:47:33 AM »
Did you remove the cotter pin on the back and push on the pin?
« Reply #2 on: October 15, 2023, 11:50:11 AM »
Back side
Offline Bodi
« Reply #3 on: October 15, 2023, 12:04:33 PM »
There are 3 common ways.
- get a working master, bleed as well as possible, then pump the piston and pad out.
- Air compressor. Relatively low pressure might work but can make the pad and piston quite speedy missiles plus spit out brake fluid at high velocity. Putting the dead side back on and wrapping in rags is advised.
- Grease gun to the slave piston. Not sure how to connect one to the caliper body but they create a very very high pressure.
Offline Rnobx67
« Reply #4 on: October 15, 2023, 12:12:09 PM »
Back side
yeah this side I removed it not bigdeal. thanks
Offline Rnobx67
« Reply #5 on: October 15, 2023, 12:19:54 PM »
thank you, good ideas :
1. will try the recently repaired master cylinder with it.
3. if I manage to find my grease gun, but think I need a new one.
thank you @Bodi
« Reply #6 on: October 15, 2023, 12:29:22 PM »
The master can create about 300 PSI, but if that isn't enough, the grease gun can do much greater pressures. I've always been able to get the thread on the end of the grease gun's pipe to just barely thread into the banjo bolt's 10mm hole, but others have used a grease zerk with the proper 10mm thread. The gun also works on stuck masters.
Offline Rnobx67
« Reply #7 on: October 15, 2023, 12:36:07 PM »
I've read that a guy let sink the all assembly in brake fluid, does it seems to worth a try ?
« Reply #8 on: October 15, 2023, 01:19:04 PM »
Nope.
« Reply #9 on: October 15, 2023, 01:44:20 PM »
I always use a grease gun, remove the zerk adaptor and the pipe will screw into the caliper pipe hole approx 1 1/2 turns which is enough, pump away till piston comes out then spend a day or two cleaning the caliper!
Offline Kelly E
  • Geriatric Hooligan
« Reply #10 on: October 15, 2023, 05:04:08 PM »
It's hard to remember to pump the pistons out before I take the system apart. But if they still work it's the easiest way. If I forget I try air next. The grease gun is the last resort.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #11 on: October 15, 2023, 05:20:18 PM »
I always use the grease gun. Safest and never fails…… years ago I took one of the furl nuts from a used metal line (that screws into the caliper) and drilled/tapped it for a standard grease fitting. Just wind it in, snap on my grease gun and out they come.
« Reply #12 on: October 16, 2023, 02:02:36 AM »
Remove caliper bleeder screw, gently thread the hose or pipe from the grease gun in, not forcing it. You don't want to damage the threads. You will get a tiny bit of grease oozing out near that joint. Don't worry about it. Pump caliper full of grease forcing piston out. Scoop out the slug of grease, disconnect your grease gun. Wipe out as much grease as you can. The slug of grease not contaminated can be put in a small container for use on something in the future.
Brake parts cleaner sprayed in the caliper bleeder screw opening and caliper body will remove rest of the grease. Clean the groove for the caliper seal and replace the seal with a new one. Lube that seal with either brake parts assembly lube or red rubber grease or brake fluid.
If you are going to repaint the caliper for this before prepping the caliper for reassembly, of course...
You can cure the caliper paint on the bike if you don't have a small toaster oven you use for hobby stuff (don't use it to warm food anylonger!).
« Reply #13 on: October 16, 2023, 02:53:58 AM »
Screwing greasegun into bleeder wont work as grease will come out of pipe fitting
Offline Rnobx67
« Reply #14 on: October 16, 2023, 06:47:20 AM »
thank you all, I've tried the master cylinder with no luck. Now I have to find my grease gun (maybe at a friend's place) or buy a new one a give it a try :) so much counsel for that option and, a lot of hope :P
Offline Rnobx67
« Reply #15 on: October 19, 2023, 08:12:33 AM »
I was a little hopeless, BUT I WAS WORKING SMOOOTH, so happy how it works.
« Reply #16 on: October 19, 2023, 09:22:04 AM »
 I recently did a couple F1 type calipers, on one I pumped the piston and pad out with a M/C and the other one I did with a grease gun. I only got one thread started but it was enough.
 I scooped the grease out and put it into a spray can cap, now I have some pretty clean grease for whatever use. The original F pad (sometimes?) has an o ring around it that needs cleaned and I lubed it with a film of silicone high vacuum grease too.
 I bought pistons and seals from 4-1, they are K&L brand and decent enough quality.
« Reply #17 on: October 20, 2023, 05:31:28 AM »
Looking at your photos, I’d plan for a new piston. That one looks pretty corroded.
« Reply #18 on: October 20, 2023, 09:49:56 AM »
Grease gun will definitely work.  I would only use a hand operated grease gun. Beware of the old air operated chassis greasers that had 5 or 15 gallon grease containers they have a lot of pressure when connected to 150+ air supply.
« Reply #19 on: October 20, 2023, 09:57:43 AM »
The gl1000 rear master cylinder kit (caliper) is the same for the F1 but you’ll have something left over that the F1 doesn’t use but the gl does.  I haven’t forgotten what’s not used it’s just that my mind is like and old VHS tape it’s there,  it’s just hard to get it rewound to the right place when I want to..🤪
« Reply #20 on: October 20, 2023, 11:55:43 AM »
If you can get Tourmax kits i am told by a trusted uk member they make for Honda
Offline Rnobx67
« Reply #21 on: October 20, 2023, 05:21:59 PM »
Thanks I,ve order a new piston, do you know how to remove the circlips in the master cylinder, now the spring works couldn't see it...
« Reply #22 on: October 21, 2023, 04:09:53 AM »
You need the special Honda circlip pliers plus a lot of wd40 and even more luck.
When i had a lot to do i use to use oxy acetylene down the hole to remove rust
« Reply #23 on: October 21, 2023, 04:39:38 AM »
there is a special place in hell,for the guy that designed where that #$%*ty circlip should reside!!
Offline jwurbel
« Reply #24 on: October 21, 2023, 06:04:39 AM »
+1
