Working on assembling my '71 CB500 wiring. I'm using a new main harness and sub-harness for a '72-'73 with the spade connector plugs. I also have a later model sub harness mounting plate to match the spade connector plugs.
The issue I'm having, is my original stator has the old style round pin plug. I'd like to change the plug to match the new harness 9-pin spade plug but can't seem to find anyone who sells them.
I bought the sub-harness from 4-into-1, and they don't sell the male plug to fit their harness, or even a new stator with the correct plug attached. I checked Common-Motor too, and they only sell 4,6, and 8 pin plugs.
Is there a source for the correct 9-pin spade male connector out there? If not, does anyone have a good used stator wire harness that they want to part with?
Thanks,
Pete
