My K6 got closer to 0.0020".
Found replies about the looser clearance to be ok, more oil flow that can be good with more power.
http://forums.sohc4.net/index.php/topic,69907.0.htmlI had used green shells, then brown, finally back to green.
Green looked better after use than brown. Scuff marks, not catastrophic.
Here that setup with slightly used green and new brown.
http://forums.sohc4.net/index.php/topic,155014.0.htmlGreen went back shortly after when engine had to be opened due to upper case massage for bigger bore.
I used assembly lube in all those assemblies so the first startup should have been ok.
Crappy mineral oil 10W-40  as break-in oil the first 1000km might be one reason.
APE Ultra crank with carillo rods.
Now 970cc. Last 2 dyno runs 107 whp.
That crank setup has done closer to 45.000km, >100whp most of it.
It runs fine. No bad sounds inside. Street use. It is the dyno visits that torture it
My almost stock K2 got the clearances in same range. Also green shells and BBBBB case.
I have a set of new brown shells I found for half price on eBay.
If I should open that engine again and if the shells should look bad.
No Kawasaki vibrations as mentioned in the old thread with Hondaman and Mike Rieck.
APE crank is balanced not only lightened so the engine runs really smooth. Alternator is lightened too.
