Author Topic: My 1975 CB400F restoration project  (Read 3135 times)
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« on: January 14, 2024, 01:46:22 PM »
Hi all i am going to start this thread documenting my recently acquired CB400F Restoration project.
I picked up this bike a couple months ago locally in Seattle for a Very good price. It has just over 20K miles on the clock. It had lots of corrosion and wear that you would expect from a 49 year old bike.
I was able to ride it over the last couple months to make sure it runs good and does not smoke. great compression and pulls very strong. Didn't know it was a six speed until my second ride. also nothing sounds like these small SOHC 4's.
I have been collection new parts,pieces and fasteners  from EBAY, CMS.NL and  David Silver Spares. I love to restore back to Factory Original as possible
 here are a couple pics before and in progress
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Re: My 1975 CB400F restoration project
« Reply #1 on: January 14, 2024, 01:50:48 PM »
This was My project last week. cleaning, restoring and re-facing the gauges.
I am going to work from front to rear.
Front Rim is next.
« Reply #2 on: January 14, 2024, 02:00:09 PM »
Those gauges look great! My wife rode a  1977 400F for years. We painted it to match our cb550K and cb750K. One of the best bikes Honda ever made! Nice project!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #3 on: January 14, 2024, 02:21:50 PM »
great looking set of bikes.
Wondering about the blinkers on these bikes?  did all US Models have the Larger 22mm blinkers? this had the small ones in the rear 14mm and large up front.
All the CB400F s i see overseas have the smaller ones?  i am having a hard time finding the correct stays for the rear.
I made these from Parts i had laying around. they are too short but will work for now.
Offline Mark1976
« Reply #4 on: January 14, 2024, 02:22:56 PM »
   Congratulations, you've a great bike there. I think keeping it as stock as possible is a great choice. I own a '77 as well, though far from stock, I've had it going on for 35 yrs, it takes a licking and keeps on ticking. A great bike...
Start with the end in mind...
Offline Mark1976
« Reply #5 on: January 14, 2024, 02:29:01 PM »
Mine have the larger front and rear...
« Last Edit: January 14, 2024, 02:30:40 PM by Mark1976 »
« Reply #6 on: January 14, 2024, 02:38:52 PM »
The Hondas in Canada got the larger blinkers in  starting 1976. The rear stalks on my wife’s were equally short, I think someone had cut them shorter. I just left them.
« Last Edit: January 14, 2024, 02:40:52 PM by BenelliSEI »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #7 on: January 14, 2024, 08:15:09 PM »
I started in on the front rim restoration this weekend. I have a new DID rim and Spokes from CMS.
I always start with the the rubber still on and clean up the disk by spinning the tire and using 220 grit on a sanding block until all the black marks and glazing is removed. I hold the axle up with 2 boards bolted  to the bench sticking out about 18". I don't have a lathe to face them off so this is the next best method for me to make them look like new.
The Bearing were howling when i was cleaning up the Disk.  The Spanner nut has 2peen marks that need to be drilled out ever so slightly , after drilling out the peen marks, I then heated the hub up with a heat gun. Nut came out with ease and both bearings tapped out with ease. I ordered new bearings and a seal. they should be here by tomorrow.
I use aircraft stripper to remove all the factory clear coat from the hub. the pictures i posted are post clear removal only. I will sand with 400/800/1500 before polishing.
I will sand and polish the hub tomorrow after i install the bearings,i'm hoping with using heat they will drop right in.
I will then clear coat the  hub. i always use catalyzed automotive clear. just 1 coat so it will protect and not chip off.
« Last Edit: January 14, 2024, 08:35:54 PM by Ozzybud »
Offline denward17
« Reply #8 on: January 14, 2024, 08:25:47 PM »
Nice looking project.
What brand of aircraft stripper do you use?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Last Edit: January 14, 2024, 08:55:01 PM by Ozzybud »
« Reply #10 on: January 15, 2024, 01:53:55 AM »
Yes the 400/Fours in the US all came from the factory, as well as all the big bikes from 1975 to 78 with the big turn signals.
Back in 76 when I was parts manager and I had to get my new K6 750, I replaced the big signals with the smaller ones, as I had the availability of parts......so I had to make it my own 😎
The 400fours are a great little package of a bike. I worked on a friend's 76 this fall replacing fork seals and a new chain. I took it for a good test ride to be sure it was safe to hand back over to him, actually his dad was riding it while he was recouping from a work injury as his lawyer advised to stay off the bike until they had the settlement..... so I exercised it for him...
I have another friend, the owner of Honda Restoration Parts, that bought two 76 400s with low miles, as part of a package deal of his shop/house from an retired racer of 400s. I'm doing a clean out of the tanks(light surface rust in them) to prepare for getting them running when he gets back in April so he can sell them and his collection as he is getting ready to retire and wants to downsize as he doesn't ride anymore and wants to sell the parts business and property. He'd make a package deal for the right buyer. He and his wife have had a great time buying and selling the parts over the years but it's time to let a younger person that wants to have an opportunity to get it.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #11 on: January 15, 2024, 04:44:24 PM »
Nice collection Newday77
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #12 on: January 30, 2024, 05:16:15 PM »
A little update on my progress. I got the front wheel re-laced and trued. Detailing the parts and pieces as I go. Using as many new Honda Fasteners and Parts  as possible. Replaced the seals in the front forks and polished up. I have a really nice uncracked headlight bucket that i need to paint and then i will be complete with the front clip. I bought 2 NOS headlight rings for the CB360 a couple years ago. Nice to find out its the correct part for the CB400F as well.
Offline denward17
« Reply #13 on: January 30, 2024, 06:54:39 PM »
Looking good Ozzybud!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #14 on: February 01, 2024, 02:05:09 PM »
Got some minor bodywork and a nice shiny base/clear coat on the procured headlight bucket today.
Also started in on re-rimming the rear wheel.
This is very satisfying work for me, just to be able to do it and go from rusty and corroded to like shiny new. It looks like the bearings had been replace recently so we are going to roll with the existing ones.
Learning new things in retirement makes it all worth it!
Offline Galactica
« Reply #15 on: February 01, 2024, 03:05:49 PM »
Really nice bike.  A CB400F would be my next project should one fall into my lap.
Offline jakec
« Reply #16 on: February 01, 2024, 03:47:33 PM »
I have restored a 400 as well. What a slog. Never again. Lol.
I always wanted to rebuild my wheels with DID shouldered aluminum rims. I still may do it one day. Unless a set of alloy wheels shows up for a good deal.
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #17 on: February 05, 2024, 01:39:20 PM »
I got The top Bridge completed today and made sure all the electricals were back in working order.
I also Got the rear wheel re laced and trued. polished and clear coated the hub over the weekend.
Offline denward17
« Reply #18 on: February 05, 2024, 02:18:56 PM »
^Dang that looks good!
« Reply #19 on: February 05, 2024, 02:30:36 PM »
Really nice work! Well done.
Offline Mark1976
« Reply #20 on: February 05, 2024, 04:13:40 PM »
Looks like new...
Online Stev-o
« Reply #21 on: February 06, 2024, 07:34:30 AM »
Nice project and excellent workmanship!
Offline Kelly E
  • Geriatric Hooligan
« Reply #22 on: February 06, 2024, 03:29:52 PM »
Instead of fumigating ourselves we use brake fluid left over from bleeding to strip paint and clear coating. It works great, it's cheap and not super toxic.
Here's our 75' CB 400-4 we resurrected from a 30 year sleep. We finished up in early 2017. It's not a restoration it's a rider and always starts right up.  8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #23 on: February 06, 2024, 04:51:35 PM »
Nice looking bike Kelly!
Thanks everybody for the encouragement. I am way to much of a perfectionist.Sometimes i go overboard. Realizing that nothing is perfect!!
I got the Clutch basket Kit installed today! happy to have that Rattle go away.It will be some weeks before i can test it out.
« Last Edit: February 06, 2024, 04:54:49 PM by Ozzybud »
« Reply #24 on: February 06, 2024, 05:12:57 PM »
Excellent idea for using the brake fluid for stripping the paint.
