Author Topic: “Put Your Right Foot Out”  (Read 1342 times)
« on: January 23, 2024, 05:55:42 PM »
Test fitting hardware before installing the motor in my cb750K6. Ever notice the right foot peg is significantly further ahead than the left? I wonder why?
Re: “Put Your Right Foot Out”
« Reply #1 on: January 23, 2024, 06:24:05 PM »
Clearance for them large feet Americans to kick start….🤪.  ?
Offline denward17
« Reply #2 on: January 23, 2024, 06:26:47 PM »
I was thinking clearance for large feet to shift on the left side (alternator interference)
« Reply #3 on: January 23, 2024, 06:28:16 PM »
Both good suggestions! I wonder.
Online HondaMan
« Reply #4 on: January 23, 2024, 06:40:16 PM »
This was the most-common question that 750 owners would ask whenever they got together in numbers - with beer.
While I never heard Honda weigh in on it, some of my favorites were:
"It offsets the massive torque of the engine during acceleration."
"It helps keep your balance during the speed wobble when you're decelerating and let go of the handlebars" (this one is actually due to the offset front wheel...).
"It's because the alternator is in the way of my boot when I try to shift."  (I think this one is pretty close?)
"It's because the oil tank on the right side is heavier than on the left, so this makes you shift your balance to match things up". (Huh?)
"Honda wasn't going to have a kickstarter at first, then decided later to have one, so the frame had to be modified." (Maybe?)
« Reply #5 on: January 24, 2024, 07:27:27 AM »
Yes, actually have noticed this but never gave it much thought why.
« Reply #6 on: January 24, 2024, 08:08:02 AM »
Alternator/ boot clearance makes sense. It’s obviously very deliberate. I wonder what #1250 looks like??? Will check.
« Reply #7 on: January 24, 2024, 09:02:35 AM »
 It had something to do with the Hokey Pokey.
Offline Mark1976
« Reply #8 on: January 24, 2024, 11:26:42 AM »
YEEESSSSS!!!!
Lol....
Start with the end in mind...
« Reply #9 on: January 24, 2024, 12:08:41 PM »
Interesting, my Sandcast #1250 is the same. I wonder if the part is the same on a cb450? Lots of parts just moved over.
« Last Edit: January 24, 2024, 03:04:40 PM by BenelliSEI »
Offline lash
« Reply #10 on: January 24, 2024, 01:16:14 PM »
They are all 1 1/2” offset. Perfect fit if you have a right leg longer than the left…
Offline spotty
« Reply #11 on: January 24, 2024, 03:59:30 PM »
well thats awkward, since i had my left hip replaced my right leg is now about an inch shorter than the good one, though i can feel my right hip starting to go so when i get that fixed they'll be the same length again
i blame Terry
Offline Trevor from Warragul
« Reply #12 on: January 24, 2024, 09:38:50 PM »
It's obviously done to compensate for one testicle hanging lower than the other, ensuring the rider doesn't squish his nut sack.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #13 on: January 25, 2024, 06:43:26 AM »
I guess I need to go look, never noticed this.
Online HondaMan
« Reply #14 on: January 25, 2024, 06:41:39 PM »
Now it will drive you nuts!
:o
