Author Topic: NOS CB750A Engine  (Read 3383 times)
Online BenelliSEI
NOS CB750A Engine
« on: February 07, 2024, 05:36:58 AM »
Last night I was offered a complete cb750A engine (no carbs). Supposedly ex Honda Canada warranty part, never run, from a dealer inventory. The gentleman that has it wants it gone. Curious;
1. Does anyone desperately need one of these?
2. Is the top end interchangeable with a cb750K. Good source of new parts?
3. Is the camshaft unique to this engine?
4. What else is interchangeable? Crank, rods?
Thanks for your expertise!
Re: NOS CB750A Engine
« Reply #1 on: February 07, 2024, 11:34:23 AM »
I have a friend here that has a 76 A. I'll ask him. Cost?
Offline redrider1940
« Reply #2 on: February 07, 2024, 11:46:52 AM »
Do you know what your it is?
Not much is going to be interchangeable. The top end is a detuned version of the K so you probably would want to use it even if it could be bolted on. This engine is also a wet sump and not dry like the K. The transmission is of course very different.
« Reply #3 on: February 08, 2024, 03:21:28 PM »
 The one I took apart had a 392 head, cylinders and pistons. The cam is smaller and the stock carbs are 26mm, like a kz1000 oddly enough. The trans drive does have a hi-velocity type chain so the crank gear is different. They have a funky parking brake, it might work off the side stand, I'm not sure so it might not affect the engine.
  I still haven't split the cases, I just want to see what's in there. It looks like a torque converter and two clutch packs. Probably where the new dual clutch transmissions originated.
Online BenelliSEI
« Reply #4 on: February 08, 2024, 05:28:51 PM »
Don…. From what you’ve seen I could use the head, barrel and pistons on a K motor? This stuff might be like new……
« Reply #5 on: February 08, 2024, 10:48:29 PM »
Do the CB750A pistons interchange with a CB750K,as far as compression and squish shape ?
« Reply #6 on: February 09, 2024, 03:45:49 PM »
 Yes, I think mine has a regular 76 top end except the cam. Guys have used the A cams for a mileage/torque motor.
« Reply #7 on: February 09, 2024, 04:21:11 PM »
Do you have a running CB750A Don ?
Online BenelliSEI
« Reply #8 on: February 11, 2024, 07:27:32 AM »
I’ve decided to pick this up, next week. Will post pictures. No idea what I will do with it! If anyone needs it as a complete unit, let me know. Note that I am 60 miles N.E. Of Toronto, Ontario, Canada. L0A1A0.
« Last Edit: February 11, 2024, 08:40:35 AM by BenelliSEI »
« Reply #9 on: February 11, 2024, 10:04:38 PM »
 Nope, I parted one out that was abandoned in a fence row. It had no title and was outdoors for a long while. I still have some of the good parts and the engine. I took off the top end and shoved the engine under the shelf for future parts use. I saved the wheels, forks and swingarm, I laced the rear to an F disc brake hub and put the front on my drag bike frame.
Online BenelliSEI
« Reply #10 on: February 28, 2024, 01:57:12 PM »
This one will end up “under a bench” too. Going to have a look to see how clean it is inside first…..
« Reply #11 on: February 28, 2024, 02:55:49 PM »
Do you have a shop cart to move it around ?
« Reply #12 on: February 28, 2024, 04:56:57 PM »
 I've been using the harbor freight small furniture carts, they used to cost $7 on sale.
Online BenelliSEI
« Reply #13 on: February 28, 2024, 07:56:23 PM »
That’s what it’s on. Bought a pair at a garage sale. Someone tastefully covered them in old carpet too!
