Author Topic: CB750A Output Shaft Oil Seal  (Read 1688 times)
Offline LiveeviL81
  • Turbomatic
« on: February 10, 2024, 12:05:36 PM »
Hey guys,
Ordered an 77-78 Output Shaft Oil Seal from CycleX, hoping it would be the same as the A, but after comparing it to my old one, it is thinner and slightly smaller OD on the seal. I think I can get it to sit on the shaft, but not sure if it being thinner won't allow it to seal correctly. Where else would I source one?
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm (Honda CB750 77-78 Oil Seal)
Kaleb
Young, Dumb, and Broke, hoping to fix 2 of those.
Offline newday777
Re: CB750A Output Shaft Oil Seal
« Reply #1 on: February 10, 2024, 12:53:44 PM »
You need the seal behind the front sprocket?
Stu
My current rides
Prior bikes....
Offline kmb69
« Reply #2 on: February 11, 2024, 07:21:01 AM »
It is a non-standard size seal - 34x62x13. Non OEM seal that should work, 34x62x12 available:
https://avxseals.com/products/shaft-oil-seal-tc34x62x12-rubber-covered-double-lip-w-garter-spring-id-34mm-od-62mm-34x62x12-34-x-62-x-12-mm
« Last Edit: February 11, 2024, 07:30:10 AM by kmb69 »
Offline LiveeviL81
  • Turbomatic
« Reply #3 on: February 12, 2024, 11:45:28 AM »
Yessir, for a 78’ CB750A.
« Reply #4 on: February 12, 2024, 02:07:32 PM »
Offline LiveeviL81
  • Turbomatic
« Reply #5 on: February 12, 2024, 02:32:47 PM »
Partzilla shows two, one available one not.
https://www.partzilla.com/catalog/honda/motorcycle/1978/cb750a-a-750-hondamatic/top-clutch-countershaft
Looking for #28, looks like 29 is the part I got (assuming the 7 is the thickness) Must be for the normal CB750's. I'll go ahead and order it off the website kmb69 provided.
Offline kmb69
« Reply #6 on: February 13, 2024, 06:00:48 AM »
It's a rather sucky arrangement, but both are used together in the A's.
