Author Topic: 5.5 mm ID Fuel Line  (Read 2202 times)
5.5 mm ID Fuel Line
« on: March 12, 2024, 07:38:01 AM »
This long length of fuel hose arrived from Japan in just over a week. Via Japan Post, no extra Duty or Fees! Not sure about in the US, but here (Canada) the dealers don’t even want to order it for me. Great deal.
Re: 5.5 mm ID Fuel Line
« Reply #1 on: March 12, 2024, 09:23:17 AM »
On ebay uk we have a firm we can get hose from inwhatever length you want, i can never do links but the item number is 130740225601
« Last Edit: March 12, 2024, 09:25:51 AM by bryanj »
« Reply #2 on: March 12, 2024, 07:40:44 PM »
Great price! I've been getting it in the standard 5m length at almost 2x as much.
« Reply #3 on: March 13, 2024, 05:16:47 AM »
IIRC both VW beetles as well as vans had 5,5mm ID fuel tubes.
« Reply #4 on: March 13, 2024, 05:44:24 AM »
Mark….. Even better; it showed up yesterday (well ahead of the promised date), via Japan Post, no extra charges! It’s the right stuff, pushed onto the standards barbs, no clamps, no leaks.
« Reply #5 on: March 13, 2024, 07:46:24 AM »
What a find!
« Reply #6 on: March 13, 2024, 08:51:14 AM »
What a find!
Get some. Lifetime supply and worth every dollar. I used two lengths to hook up the remote tank on the K6 for “first start”. Pushed on perfectly and no leaks. Perfect.
« Last Edit: March 13, 2024, 04:04:45 PM by BenelliSEI »
« Reply #7 on: March 13, 2024, 04:07:10 PM »
This photo shows the item number and the vendor I purchased from.
« Reply #8 on: March 13, 2024, 04:20:07 PM »
Just bought one! :D
This will help cut a few $$ out of the carb rebuilds that show up here. I've been buying Honda's 6m package, pretty pricey stuff that way.
Offline Flyin900
« Reply #9 on: March 13, 2024, 04:29:47 PM »
I have been able to get the shorter length of 10ft from Barrie Honda in Canada as needed, with this last batch bought late last year. John, you got the motherlode there with as noted a lifetime supply which is great, as items get discontinued on a regular basis.
Here is the SKU and it is genuine Honda 5.5mm fuel hose.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
« Reply #10 on: March 13, 2024, 04:50:08 PM »
Thanks! I’ll file that away. What did Barrie Honda charge for it? Cameron Cycle told me they couldn’t get it!
« Reply #11 on: March 13, 2024, 07:35:47 PM »
That's the one I have been getting until now, but it makes the hose like $6 per foot, OW! :(
Offline Flyin900
« Reply #12 on: March 14, 2024, 05:43:39 PM »
Well then it maybe NLA now, as I bought it last year. I think it was around $38.00 Cdn plus HST. So $3.80 ft. which is palatable as I still have some stock for awhile.
Offline pekingduck
« Reply #13 on: March 14, 2024, 06:46:35 PM »
Part number 95001-55008-60m is a Honda car part number too.  You can order it online at Honda Automobile Parts sites also, such as this:
https://www.hondacarpartsdirect.com/oem-parts/honda-bulk-hose-fuel-5-5x8000-950015500860m
« Reply #14 on: March 14, 2024, 08:49:04 PM »
That’s a fantastic price. You guys in the US should snap that up.
Offline willbird
« Reply #15 on: March 15, 2024, 03:39:43 PM »
if that is 8000mm and I did the math right that is 26' ?? They are asking for $26 to ship it.
This place same quantity, about same price but only $9.41 to ship.
https://honda.oempartsonline.com/oem-parts/honda-bulk-hose-fuel-5-5x8000-950015500860m
I need to find an air tight container to store it in perhaps.
I have been running some weird 1/4" Tygon (probably counterfeit) with clamps, this will be better.
Bill
« Last Edit: March 15, 2024, 03:41:38 PM by willbird »
« Reply #16 on: March 15, 2024, 03:52:11 PM »
I used it again today. Worth every penny.
Offline Flyin900
« Reply #17 on: March 17, 2024, 10:36:25 AM »
FWIW here is the Honda SKU for the float bowl overflow hose that is always rock hard after 50+ years on there, or totally missing from the carb bank after all these years.
Offline TideWater2
« Reply #18 on: March 19, 2024, 04:56:09 AM »
BenelliSEI,
Did Honda use clamps on the 5.5mm lines from the factory?
3 - 1971 CB750 K1s
« Reply #19 on: March 19, 2024, 05:35:38 AM »
BenelliSEI,
Honda used wire clamps from the factory.
« Last Edit: March 19, 2024, 05:39:06 AM by newday777 »
« Reply #20 on: March 19, 2024, 05:37:46 AM »
BenelliSEI,
Yes. The fine, single wire style with a circular loop at both ends of the circle. I really believe they used them to finish the job and limit liability. On bikes with simple gravity feed tanks, I don’t bother.
« Reply #21 on: March 19, 2024, 05:27:11 PM »
I need to correct the statement I just made. On my K6 project, this hose pushed on very tightly to the carb tees (the one between #1 and #2 carb and the one between #3 and #4), and the tee before the fuel tap. HOWEVER, when I slipped this new hose on the original fuel tap (petcock), it went on far too easily. I dug around in my bins and found a nice clean clip (as pictured above) that fit snuggly on the hose. Definitely better. Interestingly, when I measured the brass nipple on the tap, it is quite a bit smaller than the other connectors. Use the clip there!
« Last Edit: March 19, 2024, 05:28:42 PM by BenelliSEI »
Offline gearsoup
  • Maine, USA
« Reply #22 on: March 20, 2024, 05:54:21 AM »
Thanks for this thread, I've ordered myself a roll of the stuff. The OEM hose on my bike has been trimmed over the years and it's a tight fit to get things to connect without undue stretching of the hoses
Current Project: CB750-K6 (hoping for OEM look)
Future Project: CB750-K8  (likely go wild on this build)
« Reply #23 on: March 20, 2024, 07:53:20 AM »
When you use the wire clips, do you just put the clip on and then install the hose? And then just pull the hose/clip off to remove? I've always found getting any sort of tool up in there to get them off when removing the hose is tough to do.
« Reply #24 on: March 20, 2024, 08:48:21 AM »
I only used the clip on the single outlet on the K6 petcock. Squeezed it open with pliers as I pushed the hose on.
