Author Topic: 73’ CB350F carb reassembly  (Read 647 times)
Offline Vfrman
« on: June 22, 2024, 10:06:06 AM »
Pretty much done getting carbs reassembled & back on the rack. One thing bothers me: the black fuel connection btw carbs 1 & 2 with 2 o-rings on ea end: I have a noticable gap btw the shoulder of the fuel connector and the carb body. Both the o-rings on the end that goes into #2 are fully inside the hole. I just cant get the gap to close up like the one btw 3 & 4🤷‍♂️
1973 CB350F
many bikes over many years
Re: 73’ CB350F carb reassembly
« Reply #1 on: June 22, 2024, 10:27:17 AM »
Best advice I can give you is to see if Motormac's video's can help. Language is German but you can opt for subtitles. images speak for themselves. https://www.youtube.com/results?search_query=Honda+CB+350+400+Four+Vergaser+Montage+Carburetor+Assembly+Part+1
Offline Vfrman
« Reply #2 on: June 22, 2024, 10:32:24 AM »
Yes, I have been using his videos and they were very helpful, language didn’t really matter much, it was the visuals I needed. And I just fixed this, I didn’t want to have to take number one off, but I did and second try it snugged up shoulder to shoulder just fine.
1973 CB350F
Offline Vfrman
« Reply #3 on: June 22, 2024, 10:57:18 AM »
One more question: how many turns in does this screw go once the shoulder is flush?  I think the German dude was saying 2.5 turns in?
1973 CB350F
Offline Oddjob
« Reply #4 on: June 22, 2024, 10:59:49 AM »
Turn that screw in once the carbs are assembled. As soon as you see the slide start to lift, stop. Do them all the same.
