Author Topic: 1974 CB550k Boss Maroon  (Read 39618 times)
Offline brett_bike
  • '73 CB500 Four K2
Re: 1974 CB550k Boss Maroon
« Reply #50 on: August 29, 2024, 12:20:05 PM »
I have it on clop #4. I was under the impression that was stock.
It may not matter yet because I’m getting different reading on the plugs even though carbs are set the same.
Offline denward17
« Reply #51 on: August 29, 2024, 12:57:22 PM »
I had to go to the center position to lean my '76 550 out some on the bottom end.  When I tore into carbs they were in the 4th position from top, or 2nd from tip.
The bike runs much better when at operating temp, but doesn't run quite as well when cold.  I now have to fiddle with the choke a little bit more, which I am ok with.  I guess I made it a little more cold natured.
Don't know if it matters, but I also installed new Honda needles/emulsion tubes.
At center position,  probably rich at WoT if you’re induction setup is stock. You should be second from top, fourth from tip. Moving to the middle enriches the carbs (raises the needle with throttle increase, allowing more fuel). Whomever had it second position from tip was either running pods, or was errant in their assembly.
According to various charts I have seen, I should be in 4th from top.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #52 on: August 30, 2024, 08:56:44 AM »
Oops
Offline denward17
« Reply #53 on: August 30, 2024, 09:14:01 AM »
^Where does that go?  It's been a while since my carbs were apart.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #54 on: August 30, 2024, 09:15:52 AM »
It’s the main jet holder inside the float bowl.
Offline denward17
« Reply #55 on: August 30, 2024, 09:44:55 AM »
Thanks, now it registers, the butterfly as I like to call it.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #56 on: August 30, 2024, 09:59:40 AM »
That’s the one.
Used the clear tube methods again today and I guess I messed up before. The fuel level in my #1 carb was still too high so I d to remove the rack and reset/verify all the float settings…again.
When I removed the bowl I also noticed one of my bowl o-rings was pinched. Luckily it hasn’t leaked but I ordered new o-rings for all the bowls.
Offline denward17
« Reply #57 on: August 30, 2024, 12:08:58 PM »
I used a touch of wheel bearing grease in all 5 corners of the o ring for the float bowls to hold them in place.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #58 on: September 07, 2024, 02:54:47 PM »
To update what’s going g on with the bike…
By the suggestion of a fellow CB rider, I picked up some JB Weld putty and started plugging holes. My exhaust is rusted beyond repair, by the way.
On first ride it was leaps and bounds better.
It pulls smoothly all the way up the rpm range with zero stumbling anywhere. Since I only did a bench sync with the carbs off I need to go back and vacuum sync them and I’ll probably triple check the timing while I’m at it.
I was surprised but it seemed to fix the problem. I never thought holes in the exhaust would cause this sort of “acting up” of the bike but it seems it did.
I’m hoping to mount my GoPro and take it for a ride tomorrow. I’ll post a vid asap.
Thanks for all that helped try to alleviate this issue. This forum is the best!
Offline brett_bike
  • '73 CB500 Four K2
« Reply #59 on: September 11, 2024, 07:53:20 PM »
Well that was short lived. A new issue has popped up. At least I think it’s a new issue.
So the bike ran great for a couple of days. Then I’m back to the same sputtering issues until I removed the air filter, then it ran great. It’s an old filter so probably pretty clogged. I’ll be trying to track down a new Honda filter. Any recommendations on Uni vs Honda vs ? My previous CB500 had a single K&N that connected to the stock air plenum (no box) but I can’t seem to find anything like that style.
Anyhow…
So here I go again back into the entire tune up process to see what I may have missed.
Something strange happened while going through the tune up process. It’s kind of weird to describe but as I’m checking the timing with the automotive timing gun I get no flash on #3 while giving the throttle a twist to advance. I get a flash while advanced on all others. The coils are new from 4into1 and could be bad, I guess.
What’s weird is that I get a flash at idle but not while advanced in #3 only so it appears the advance unit is functioning correctly.
I’ll be testing the coils for resistance and making sure all is installed correctly.
Could the points be bad? Condensers? Would a Dyna electronic ignition system solve the issue?  I’ve used the Hondaman Tranzistorized ignition module in the past with great results.
« Reply #60 on: September 12, 2024, 07:38:18 AM »
 Condensers?
Do you have the OEM airbox? If yes, then the Uni air filter is a good option.
What brand of condensers do you have?  New aftermarket condensers seem to be trash, we've had many reports of them being bad.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #61 on: September 12, 2024, 08:07:33 AM »
Yes, stock air box.
Honda condensers. I have some stock ones sitting around from previous builds.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #62 on: September 24, 2024, 05:59:38 PM »
Been a little bit since last update.
Kind of forgot where we left off but I purchased a few new parts.
Thinking that my rich (1-3) and lean (2-4) issue was due to condensers and/or points I ordered a Dyna electronic ignition. I’ve used Hondaman tranzistorized ignition in the past and wanted to try the dyna. I also picked up some used 4 into 2 exhaust. My original 4 into 4 were too rusted to salvage so I wanted to get something that didn’t look like Swiss cheese while trying to tune this thing.
I’m still getting the rich/lean issue mentioned above but it runs smoother without the air filter installed. I have no idea how old it is and it’s tough to tell how caked it is.
I’m thinking that since I have now replaced all the ignition parts I will dig back into the carbs and perform a test. I’m going to swap needles from the rich carbs to the lean carb. Install new plugs and do another plug chop. If the rich condition follows the needles then I’ll replace them. I guess there’s a chance they are not tapered correctly and letting too much fuel to pass.
Thought?
I gotta be honest. As frustrating as this is, I love the challenge.
Offline denward17
« Reply #63 on: September 24, 2024, 06:37:05 PM »
What kind of needles are in the bike now?  Do you have pics with the numbers stamped on them?
« Reply #64 on: September 24, 2024, 08:23:21 PM »
If this bike came to me for repair(after seeing what you've done to correct the ignition),I would remove the carbs. one last time and go through them 'with a fine tooth comb' in a manner of speaking.
Remove all the emulsion tubes and check all the needle jets:both the i.d. and how they all fit into the carb. bodies where each needle jet/nozzle is needing to seal against the carb,etc.
Take plenty of time with them and as denward17 has mentioned about the needles;the problem may be in the needles and needle jets,but either way.. IT'S A CARBURETOR PROBLEM.
Take your time   and inspect every little thing in them,no matter how minute;finally re-install them after your 100% sure you've checked everything in them.
« Last Edit: September 25, 2024, 08:00:57 AM by grcamna2 »
Offline brett_bike
  • '73 CB500 Four K2
« Reply #65 on: September 25, 2024, 07:23:14 AM »
Hopefully that’s a typo above. Cylinders 1/4 and 2/3 are married with the coils and points. If by some chance you have things mis-wired, your carbs cannot be held accountable.
Just checking…?
Nope, not a typo. Although I was it was.
I don’t get it either.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #66 on: September 25, 2024, 08:58:56 AM »
To be clear, you have the plug wires correctly routed 1/4-2/3 from the ignition, but carbs 1/3 and 2/4 are behaving as "pairs"?
Correct
Offline brett_bike
  • '73 CB500 Four K2
« Reply #67 on: September 25, 2024, 12:29:39 PM »
272304 on each needle. Clip in middle #3 position
Offline denward17
« Reply #68 on: September 25, 2024, 01:04:17 PM »
^That's what my new Honda needles are, so they should work good if not damaged.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #69 on: September 25, 2024, 01:06:11 PM »
They were pretty gummed up when I got the bike and opened up the carbs. Would it be possible I got a little too aggressive when cleaning them?  After they spent some time in the ultrasonic cleaner I used 0000 steel wool to take off the remaining varnish.
Offline denward17
« Reply #70 on: September 25, 2024, 02:25:40 PM »
Did you by chance measure the needles?
Here was my new ones:
Length:
272304 = 55.85mm
Tip diameter:
272304 = 1.41mm
Offline brett_bike
  • '73 CB500 Four K2
« Reply #71 on: September 25, 2024, 04:15:00 PM »
Length:
272304 = 55.85mm
Tip diameter:
272304 = 1.41mm
55.85 length
1.2 at tip.
Offline denward17
« Reply #72 on: September 25, 2024, 04:41:08 PM »
Length:
272304 = 55.85mm
Tip diameter:
272304 = 1.41mm
55.85 length
1.2 at tip.
That 1.2 at the tip shows wear, one reasong for richness I guess...(assuming we measured in roughly the same area).
Offline brett_bike
  • '73 CB500 Four K2
« Reply #73 on: September 25, 2024, 04:50:12 PM »
Length:
272304 = 55.85mm
Tip diameter:
272304 = 1.41mm
55.85 length
1.2 at tip.
As close to the tip without hitting the taper point.
But they all measure the same, and my readings are 1-2-3-4, rich-lean-rich-lean.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #74 on: September 25, 2024, 04:54:47 PM »
I have the carbs off the bike again and confirmed all passages are clear. As well as all  brass parts are clean of debris
While I was working on the bike I checked fuel flow and double checked coils were wired correctly.
