Author Topic: 1974 CB550k Boss Maroon  (Read 39114 times)
Offline brett_bike
  • '73 CB500 Four K2
Re: 1974 CB550k Boss Maroon
« Reply #100 on: May 05, 2025, 02:40:05 PM »
Looking forward to this.
Offline brett_bike
  • '73 CB500 Four K2
« Reply #101 on: May 10, 2025, 04:16:22 PM »
So I picked up some new pvc harness sleeves from vintage connections. I purchased things from them in the past they’re great to deal with and they shipped quickly.
Does anybody have any advice on how to put the wire harness through the PVC sleeve?
I’ve done it for a smaller section of wireless to go through the handlebars, but this is a cluster of wires in the harness to fit through that PVC sleeve.
Online grcamna2
« Reply #102 on: May 10, 2025, 05:51:05 PM »
I have used a fine mechanics wire,carefully wrapped/spiraled around the ends of the harness wires,into a pack.
Might help to spray them w/ WD40 a little so they will slide through the PVC sleeve. Pics ?
« Last Edit: May 10, 2025, 11:08:51 PM by grcamna2 »
« Reply #103 on: May 10, 2025, 11:05:51 PM »
Certain sizes will not fit without removing the bullet connectors, sliding the pvc on, and then re-crimping new bullets...a lot of work.
« Reply #104 on: May 11, 2025, 07:11:27 AM »
I have an old tin of electricians cable pulling grease (yellow). It works great.
« Reply #105 on: May 11, 2025, 07:54:20 AM »
Dish soap diluted and sprayed on and inside?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #106 on: May 26, 2025, 01:42:34 PM »
Overdue update.
For the time being I cut open the pvc lengthwise and electric silicone taped the harness. I replaced a few corroded wires from the front blinkers that, I think, was the culprit. Since the repair I’ve done about 50 miles with no issues.
Next thing to sort out is the bluing of the exhaust pipes. 1 & 3 are bluing but 2 & 4 are a nice golden color.
Online grcamna2
« Reply #107 on: May 26, 2025, 03:47:50 PM »
Overdue update.
Have you serviced the carburetors lately?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #108 on: May 26, 2025, 04:06:58 PM »
Overdue update.
I have. Complete tear down and ultrasonic cleaning. Original jets but new o-rings and carb sync.
« Reply #109 on: May 27, 2025, 07:00:19 AM »
I'd check the spark plugs and make sure 1&3 are not too lean
Offline Mark1976
« Reply #110 on: May 27, 2025, 08:31:51 AM »
   +1 to the above, this was incredibly common on chrome plated anything exhaust (kerker is what comes to my mind) in the very late 70's-early to mid '80's. People would just throw a pipe on without truely understanding it's affect on carburetion.
   Yet in this case, if they do appear lean, you'll have to track down the issue, it's not rocket science, one thing at a time.
Start with the end in mind...
Offline brett_bike
  • '73 CB500 Four K2
« Reply #111 on: May 27, 2025, 08:45:10 AM »
Online grcamna2
« Reply #112 on: May 27, 2025, 09:33:24 AM »
The #2 & #4 head-pipes look like they had gotten kind of overheated,at some point in the past.
Make sure the float heights are all correct.
« Last Edit: May 27, 2025, 06:24:22 PM by grcamna2 »
Offline brett_bike
  • '73 CB500 Four K2
« Reply #113 on: May 27, 2025, 10:57:06 AM »
I’ll check float heights again, but they were good during rebuild.
Online grcamna2
« Reply #114 on: May 27, 2025, 11:43:46 AM »
I use a special float height gauge which reads in mm's;I've also seen members using the 'clear tube method' and it seems to be very accurate.
The spark plug picture you posted;seems to me the crush-gaskets don't look very compressed..
Make sure to fully torque each spark plug to the correct specs,rather than have them leaking compression past the gaskets.
« Last Edit: May 27, 2025, 06:28:44 PM by grcamna2 »
Offline Mark1976
« Reply #115 on: May 27, 2025, 01:50:54 PM »
   Well, its its kinda hard to tell from that pic, they look like they've got a lotta idle time on them. But having said that, the straps (electrode) on #1 & #3 are slightly (possibily) lighter. Throw on a set of gauges make sure they're sync'd (dbl ck that all the low speed screws are set equally), if ya can do a clear tube without taking them off then, do it (looking for lower than spec). Make sure all your clamps are secure, verify there's no visible cracks in the manifold boots, check to make sure the manifold orings aren't leaking (in your tear down, the previous owner had sealer on these), its a process of elimination before having to get your hands dirty and then disassembling. It really doesn't take much for this to happen, and in most instances its more than 1 issue, however small. Most of this won't take but 20 mins total to do...
Offline brett_bike
  • '73 CB500 Four K2
« Reply #116 on: May 28, 2025, 11:00:07 AM »
I checked my float level using the clear tube method and all looks good.
I do have leaking from the #4 bowl from time to time so I installed new float needle from a previous kit I purchased. Took it for a ride today and no leaking and pulls strong.
I do need to give it a 3k mile tune up but my Morgan pro carb tune is having g issues.
The slide for cylinder 1 is sticky so I can’t be sure I’m getting an accurate reading.
Has anybody had this issues with their Morgan carb tuner?  Any way to repair?
I was considering bucking up the digi-sync carb synchronizer. Who’s used it and is it worth the money?
Offline brett_bike
  • '73 CB500 Four K2
« Reply #117 on: July 14, 2025, 04:22:32 PM »
Mid July update…
I’m currently running a cheap MAC exhaust and with the blue’ing I was getting from what I assumed was a lean condition I wanted to try a slightly bigger primary jet.
I upped the primary jets from stock 38 to 40 and it seems to pull strong and the transition from pilot jet to main jet stumbles far less than before. It does have a little blubber while just cruising in the 4k -5k RPM range. Not too bad I’m getting closer.
One more thing…I’m going through the tune up again and forgot to ask this before.
I installed the Dynatec ignition and it seems that I have run out of ‘adjustment’. I can’t turn the plate any further clockwise to adjust the fire mark.
I don’t necessarily need to, but shouldn’t it be more centered in the slots?
