Author Topic: American Land Master UTV.  (Read 21412 times)
Re: American Land Master UTV.
« Reply #100 on: December 25, 2024, 05:52:49 AM »
+1 to above. I was only looking for a golf cart rig, but this is 5x as useful.  I like that it is made in North America and their support network is very good.
Seems to me this is the only one that is just 4’ wide. Theoretically, it should fit in the back of a full size pickup bed. It just “squeals” into my 4’ X 8’ trailer.
Offline Johnie
« Reply #101 on: December 25, 2024, 11:04:56 AM »
Middleton is a little south of me. I think I will check out the LM to see what it has to offer. Thanks for the tips.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #102 on: December 26, 2024, 09:41:27 AM »
Johnie….. Look around at used ones too. They are built tough and most of it is assembled using very generic parts, easily found or fabricated. Their parts support is excellent too. Good Luck!
Offline Johnie
« Reply #103 on: December 26, 2024, 05:38:58 PM »
Thanks for that John. I will check it out for sure. I like that fact it is all Made in the USA!
Oshkosh, WI  USA
Offline dhall57
« Reply #104 on: February 08, 2025, 01:48:18 PM »
Got my frame repaired on my ALM. Also got some things other things done to it including a new coupler kit installed. Here is a picture of mine after riding around just a short time. See the cushion coming apart. What would cause this, something in a bind or not in line :-\
« Last Edit: February 08, 2025, 03:51:21 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #105 on: February 08, 2025, 02:28:24 PM »
Which part is that w/ the cable bolted on top of?
The round alloy housing.. with the coupler ?
Offline dhall57
« Reply #106 on: February 08, 2025, 03:45:03 PM »
Rear transaxle and gear box.
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #107 on: February 08, 2025, 04:35:27 PM »
That coupler is very different than my older version. I’ll take a picture of mine tomorrow……. That 90* gearbox that takes drive to the front end was virtually impossible to drain on mine. It’s mounted in a way that makes it impossible to reach the plug. I had to 1/2 pull it out and them discovered th oil was “full” and very clean too!
« Reply #108 on: February 08, 2025, 06:47:56 PM »
Was that the one you made a way to drain it easier next time ?
« Reply #109 on: February 08, 2025, 08:10:26 PM »
It may not be properly aligned…
It has to be in line. within 1/2* degree at any speed or torque. Same with shaft centerlines…
Many believe the lovejoy type coupling can run like a u-joint.. it can’t….
Google LoveJoy couplers alignment procedure.. it’ll make you a pro at aligning them..😇
« Reply #110 on: February 09, 2025, 03:42:16 AM »
It is!
« Reply #111 on: February 25, 2025, 09:29:21 AM »
Had some fun with “Ruby” today. We finally have a bit of a thaw. Left it in two wheel drive and went sideways everywhere. Cheap thrills!
Online Kelly E
  • Geriatric Hooligan
« Reply #112 on: February 25, 2025, 09:53:50 AM »
Have you taught the grandkids that one yet? 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #113 on: February 25, 2025, 10:08:59 AM »
Not yet, but that will be next!
Online Kelly E
« Reply #114 on: February 25, 2025, 02:24:07 PM »
Everybody should know how to drive sideways, ya never know when it might come in handy. 8)
1983 Honda CB 1100F
« Reply #115 on: February 25, 2025, 04:30:08 PM »
All my kids learned in our old Suburban, in a snowy COSTCO parking lot. I then sent to a local skid school that has a huge, flooded skid pad. Money well spent. They all have cars with standard transmissions too!
Offline farmbark
« Reply #116 on: July 07, 2025, 12:48:19 PM »
@BeneliSEI, what are the brakes like on Ruby? I picked up a 2015 LM650 and the brake pedal is so stiff with barely 1/8” of travel. Trying to decide if taking it all apart is the right move or not
« Reply #117 on: July 07, 2025, 03:38:22 PM »
Honestly….. Mine is the same! I took out the central cover and cleaned and lubricated the linkage (it’s pretty crude). Then I did bleed in fresh fluid when I got it, and checked the calipers and inside the rear drums, and all was clean and well adjusted. I suspect a smaller diameter master cylinder would make a difference, but I just “stand on it”……. It runs so well I just left it alone. Is yours the Subaru 650?
« Last Edit: July 07, 2025, 03:40:39 PM by BenelliSEI »
« Reply #118 on: November 06, 2025, 10:59:51 AM »
The side X side was getting hard to start. I’d been ignoring it because the American Landmaster LM650 is notorious for a weak solenoid (part of the starter motor on the 650cc Subaru Twin). Yesterday it just would not engage, so dug in. Turns out the Amazon Key Switch I installed not long ago was the issue. No signal in the “Start” position. Replaced it with a new “Marine Quality” switch and problem solved! We’ll see how long this one lasts….
