Yes, more or less.
It was one guy that got a smoker due to this. He saw high oil level inside tappet caps. When standing on side stand more to #1.
I think he widened the oil return holes in gasket. He started a thread about this.
I had done the same when gasket holes were tight. MLS is very hard to grind.
That was a gasket with only 8.5mm holes for return if I remember correctly. Grind a little and let it cool to avoid the viton to burn.
I was very suspicous about thick HD studs and small holes feeding the head with oil.
One head had only around 8.5mm stud holes feeding the oil. Only 0.25mm around stud for oil.
So I drilled the 2 oil feed holes from gasket side with a 9.5 mm drill. Protected head with thick tape, the drill chuck can suddenly hit when going thru.
(Blew the holes to avoid burrs into oil orifices I had removed.
Early ones trickier. A friend told me how to wich I did eith my early heads. Wrote about it with photos on this forum.)
All other holes 9mm. 8 of them oil return
The first head due to nuts had dug deep into head. I had to hammer on the ex spigots to get head off, alu had married the HD studs. (Thanks to Franks frame kit, engine in frame.)
Left head at my local shop that milled all 16 holes parallel to gasket surface. Drill all holes a must.
The other heads got same hole massage.
Maybe not my K1 head yet. It will get new guides, valves and seals when the nearby shop mechanic less than 2 km away has operated his left hand, done the right earlier this year. Carpal tunnel syndrome.
He is 72 yo, no reason to stop restoring, modifying engines he has worked with since the 70's.
