Author Topic: New (for me) '77 CB750  (Read 1964 times)
Offline SantaFeHonda
« on: August 23, 2024, 12:29:29 PM »
I just took possession of a beautiful 1977 CB750. It came from Washington state (elevation 7 ft.) and now is in Santa Fe NM (elevation 7000 ft.). What adjustments will be needed to maintain best performance?
Offline denward17
Re: New (for me) '77 CB750
« Reply #1 on: August 23, 2024, 02:13:54 PM »
Welcome to the forum SanteFe, can't really help with the question but others will be here shortly.
« Reply #2 on: August 23, 2024, 02:28:13 PM »
Welcome aboard the forum SantaFeHonda
Determining that will take a lot more information.
Smaller main jets, but that will depend on what exhaust, if stock motor or built motor with??? And it will be determined by the plugs burning color. Carb condition(how clean they are and what jets are in it, Keihin brass in it still? What notch the needle is set at) and so on. There isn't a magic formula.
Back in the 70s when I toured across the country from NH (100' ASL)on my K6 I carried 4 set of jets with me to change out and do plug chops as I gained altitude to get it dialed in.
« Reply #3 on: August 23, 2024, 02:29:56 PM »
Plug colors to read how the carbs are carbing.......
Offline rotortiller
« Reply #4 on: August 23, 2024, 02:34:41 PM »
It will likely be fine, like lawnmowers and cars they shipped those bikes everywhere with the same jetting. If it throttles fine with no flat spots do not worry about it.
Offline beemerbum
« Reply #5 on: August 23, 2024, 05:16:55 PM »
Send pictures. There is a select group here who fully appreciate the '77 and '78 CB 750's as the ultimate expression of the SOHC 750
« Reply #6 on: August 23, 2024, 07:06:30 PM »
Contrary to popular belief, there is no amount of re-jetting that will compensate for the reduced atmospheric pressure as you go up in altitude; you lose 3-4% horsepower for every 1000 feet above sea level. Since a carburetor meters fuel based on the mass of the air flowing through it, and the air has less mass as you go up, it can compensate somewhat, so it can allow the engine to operate over a wide range of elevations without changes. I've ridden from sea level in CA to 11,000' in CO and back again, and never bothered with jet changes, and my riding companions didn't either. ;)
« Reply #7 on: August 24, 2024, 04:36:16 PM »
I'll ride for a week or two and check the plugs. Until then, thanks everyone, and this is a photo.
« Reply #8 on: August 24, 2024, 04:52:11 PM »
The ‘77/‘78 SOHC cb750K are hugely underrated. Great value and great ride. Enjoy!
« Reply #9 on: August 24, 2024, 06:42:34 PM »
There are a few things that are not from a K7 on your bike: the exhaust, the gas tank, and the carbs are from an earlier bike. Some would consider them an improvement. ;D
« Reply #10 on: August 24, 2024, 07:02:58 PM »
Front end looks like K6.
« Reply #11 on: August 24, 2024, 07:19:45 PM »
I noticed the fork lowers looked shorter than a K7, but not sure if there were any differences between K3-K6? A pic of the other side would show if it has the K7 smooth brake caliper or the earlier finned caliper. Either way, it makes little difference, except to the purist types.
SanteFe, I don't mean to pick your bike apart, I think it's a good looking bike and an improvement over a stock K7. ;D
« Reply #12 on: August 24, 2024, 08:35:21 PM »
I like it too!  Nice mix.
Offline M 750K6
« Reply #13 on: August 25, 2024, 12:22:20 AM »
My K6 was first sold and registered in 1977. Wonder if yours is the same? What is your engine / chassis no.?
Offline rotortiller
« Reply #14 on: August 25, 2024, 05:26:48 AM »
Look at the rear foot pegs and rear exhaust support, hidden oil tank cap kinda tells the story. K7, it's been Franken'd lol.  Nicely done and looks good.
Online MauiK3
« Reply #15 on: August 25, 2024, 07:42:08 AM »
Looks great
Might have some Yamiya parts on it to get the look.
« Reply #16 on: August 26, 2024, 09:16:49 AM »
I started looking closer after reading the posts. This is what I found. The engine # is CB750E-2434845.  The # on the pipes is HMCB750SLHM 431. The carbs are marked KEI HIN. Also, here's aphoto from the other side showing the front brake. I'm not much of a mechanic or a purist, but I do like to ride, and this thing hums.
« Last Edit: August 26, 2024, 09:21:14 AM by SantaFeHonda »
« Reply #17 on: August 26, 2024, 09:38:26 AM »
The front caliper is from a '73-'76, which uses a 38mm piston, compared to the K7 which uses a 42.8mm piston. The brake pads are also different between the two versions.
The engine looks to be a K6.
What is the frame # on the side of the steering head?
« Reply #18 on: August 26, 2024, 09:51:16 AM »
This is what a K7 exhaust pipe looks like:
« Reply #19 on: August 26, 2024, 10:04:30 AM »
The best I can tell the frame # is CB750K-2710043
Online rocket johnny
« Reply #20 on: August 26, 2024, 10:07:13 AM »
if it looks good  ( and i think it does )   runs and rides good ,,   ride the hell out of it and have fun !
« Reply #21 on: August 26, 2024, 10:15:03 AM »
That's a well-done blend of the K6 and K7! You have the better parts of both bikes as far as maintenance is concerned (and easier tuning if needed).
I like at 6000 feet, In Colorado. I can say this for the area where you live: the gasolines have been adjusted in their burn rates for the altitude where you live, within 2500 feet or so. This usually means you won't have to be concerned with 'tuning for altitude' unless you're looking for every last HP. Largely, you won't need to do anything. If the sparkplugs tend to get dark and foul, use less octane: originally the K7 Owner's Manual told you to use Premium grade, but today's fuels burn much too slowly for that to work now. So, for dark plugs, go toward Regular grade instead. Also add a couple of ounces of oil (any oil will do) to the gas tank at fillups, because our gas is now very 'dry' compared to the 1970s, so it ends to wear the top-end parts like valves guides and piston rings faster than normal.
For example: for around-town and freeway use, I run Regular grade. If I'm heading out onto the interstate for 100+ mile ride, I'll use Midgrade. If I head downhill toward Missouri or places South (TX, etc.) at low altitudes, I'll use Premium every-other tank, Midgrade the other. This keeps the sparkplugs cleaner longer and cools the engine and pipes better by burning the fuel more.
« Reply #22 on: August 26, 2024, 10:18:28 AM »
That's a K7 frame.
« Reply #23 on: August 26, 2024, 12:10:50 PM »
That's a K7 frame.
yeah, and a K6 engine.  I think I see K7 17" back wheel, but what swingarm was used and is the sprocket carrier been swapped?...curious about the 10mm chain alignment difference between K6 and K7
Offline rotortiller
« Reply #24 on: August 26, 2024, 12:20:13 PM »
Being that it has been Franken'd a bit it would be wise to see if it's been converted properly at the arse end and make adjustments if needed. Minor 5hit to deal with especially since the sucker certainly looks so very nice.
« Last Edit: August 27, 2024, 05:53:55 AM by rotortiller »
