In the worst case, the rubber will be hard and may just break off when you start removing it. Then the M15 tap thing might work (still looking for one of those locally), or else I use some jeweler's screwdrivers, like a tiny chisel, and nick & bend over an edge of the metal rim of the seal when the rubber is gone. Then I nab that edge with some small needlenosed pliers and bend it up and out.
