Author Topic: CB750 Mix and Match Madness  (Read 1519 times)
Offline Mikerts_Garage
« on: March 17, 2025, 10:02:57 AM »
Hey Y'all,
I've been gearing up to fix my CB750 K8, but the project has suffered from just a bit of scope creep....
Let me introduce you to the story so far.
Around 9 years ago I bought my first street bike; a CB750 K8, I drove 4 hours north to Idaho Falls to pick it up for $700. The bike didn't run at the time, and the front brake was seized up. It was not a hard bike to get going again. I fixed it up slowly and put around 11k miles on it over the years. When I picked it up It looked like this:
More recently, the bike looks like this:
The problem came when I T-boned a car who failed to yield when making a left turn. I was okay, a little bruised, but the bike didn't fair so well. I replaced the forks, triple tree, and front wheel before I realized the real problem was the frame. It seems the frame had twisted right behind the steer tube. This resulted in a bike that always wants to go left and wasn't stable at speeds higher than 50mph.
So, I need a new frame, I figured it'd probably be cheaper to buy a whole parts bike locally than source one on Ebay. This leads us to CB750 #2:
This bike is a $400 K6 roller that I picked up just a couple blocks from my house. The astute among you will be saying "the frames changed in 77' to accommodate longer tanks and different seats and a bunch of other stuff". You are correct, I did not know that at the time  ::)
So I thought to myself, "I like the styling of the K0-K6 bikes the best, why not try to find a way to make bike #2 work" and thus bike #3 was found and purchased:
This one is a K4 roller that was sitting outside a shop most of it's life(that's why the tank is almost all primer). Surprisingly there is no rust on the inside of the tank, nor any dents. Came with original right side cover, and reproduction left cover. Engine is seized up solid and it's missing the seat and exhaust though. Picked this one up for $300
At this point I had most of what I needed to make 2 bikes, the one I wanted to keep and one that would sell as a runner(although it wouldn't have an exhaust, and would retain the twisted frame). But it just wasn't a great plan yet, lots of awkward compromises, and none of the engines were great keepers without a rebuild(not what I want to do at this time).
So that brings us to CB750 #4:
This one is a 75' F1 that I found for $550, The owner let me do a compression test on all 4 cylinders before buying, which was very nice of him. It's got all the great F parts: chrome headlight bucket, chrome chain guard, stock 4-1 header(aftermarket muffler tho), higher compression engine, and rear disc brake. However, it's missing the seat foam and cover, side covers, headlight, and left side controls.
This is the part where I could use help from all of the CB750 compatibility experts here. I have done as much research as I could think of, but I could still be wrong about what will fit what. Here are all the frame and engine numbers if that helps at all:
-K8 Frame: CB750K-2859912, Engine: CB750E-3059939
-K6 Frame: CB750-2574731, Engine: CB750E-2464388
-K4 Frame: CB750-2521875, Engine: CB750E-2402688
-F1 Frame: CB750F-2019040, Engine: CB750E-2538876
The plan is to rearrange the 4 bikes as such:
Final bike #1 - the keeper:
-frame, tank, sidecovers, forks, and everything else to preserve the styling from the K4.
-Rear swing arm, rear wheel, engine, chrome bits, and all supporting hardware from the F1. My understanding is that the F1 swing arm is 1 inch longer, but otherwise should work with the K4 frame as long as it has the matching counter shaft spacing for the sprocket; which it should since I'm also using the engine? Also from what I've read the F engines have a bit high compression than the K's?
-Exhaust and carburetors from the K8, I like the pumper carbs from the K8 the best, very punchy. Also the 4-4 megaphone exhaust has had all but one baffle in each pipe removed. which makes it sound quite mean.
-I don't yet have a seat for this bike yet, neither the K2 or the K4 even came with a seat pan. So that will have to be sourced at some point.
-The hope is to have the best of all worlds, K4 styling, F1 brakes and performance, K8 carbs and modified exhaust.
Final bike #2 - runner to sell:
-Straight frame, Carbs, and exhaust from the F1.
-Just about everything else from the K8: Tank, seat, fenders, controls, forks, wheels, swing-arm, etc. I can't find much on compatibility between these two bikes, but from what I understand everything should match up because the seat hinges are on the same side and the tank mount spacing is the same.
-The hope for this bike is to have a decent runner to sell, everything should work and be complete, the engine will just be a little tired. The biggest problem is if I go with the K8 seat and tank, I don't think the K8 side covers will mount up(they are just unpainted reproductions). I have the F1 tank and seat pan(in okay condition), but no side covers and the seat foam doesn't exist online as far as i can tell.
Final bike #3 - just enough to run and sell:
-Straight frame, engine, swing arm and wheels from the K2.
-Carbs, airbox, and some other bits from the K4.
-K4 also came with a $30 ebay seat I'll throw on there, I ill probably use my old dented-up green K8 tank from the crash, it won't mount up well but it'll work good enough.
-front forks from the F1 probably?
- It won't have an exhaust which isn't good, but I think I can get it running open header and sell it as a project to some one. The K2 engine is questionable as the compression isn't great and the left side cover is unbolted for some reason. But I'm confident I can at least get it running.
Final bike #4 - a terrible parts bike: It's easier to say what is going to be bad about this one, as it's just a stockpile of the worst parts.
- Bent K8 frame, Seized K4 engine, horrible modified chopper forks from the K2, and whatever other bad parts come off the other 3 bikes.
- This one will probably sit on the side of the garage under a cover, I will snag parts off it if I ever need to.
All of this also means I will probably have a F1 tank and seat pan/ cowel to sell, I will post that here if that is the case.
I think I have enough oil tanks, hoses, cables, etc across the 4 of them to make it all work. I won't know for sure until I start digging in.
Please let me know what y'all think, and if you have any notes on compatibility :)
Thanks for reading -Kyle
Running and Riding: 71' Honda CT90, 73' Honda CB350F, 20' KTM EXC-F 500.
In Progress: 70' Suzuki TS90, 74' Honda CB750K
Back Burner: 66' Honda CB160, 73' Yamaha TX650
Forgotten in the Oven: 70' Honda CL350, 77' Honda XL350
Others I have mechanical custody of: 69' Honda CL125, 71' Honda CT90, 74' Honda Z50, 77' CB550F, 79' Honda CX500
Online CB_Jeff
Re: CB750 Mix and Match Madness
« Reply #1 on: March 17, 2025, 11:37:40 AM »
Hey Kyle, a nice set of bikes you have there, too bad about the K8.
I'll follow your thread, I have the parts to do the same thing with an early-K frame.  The tricky part is rear brake M/C and pedal, they are not fully compatible with a KO / K6 frame.  It's been done, but might require some fab work and / or welding
I will follow your progress!
« Last Edit: March 17, 2025, 11:42:35 AM by CB_Jeff »
« Reply #2 on: March 17, 2025, 01:57:56 PM »
Following. Lots to do!
« Reply #3 on: March 17, 2025, 03:18:18 PM »
As an F and K owner and lover, I wouldn't bother with the F swingarm and rear wheel/ brake.  The F bike disc system is primitive and as the rear brake only does approx. 25% of the stopping power there is really only the penalty of the excess weight and service parts for those calipers are getting extremely scarce.  Also, the F swingarm is longer and will just make an already extremely stable bike even more so.  I think the 75/76 F countershaft sprocket lines up with 69-76 K rear sprocket making the F engine a bolt in replacement.  It's the 77/78F that have the countershaft 10 mm outboard.
Offline Honda Hansel
  • Sherwood Park AB
« Reply #4 on: March 18, 2025, 07:05:50 AM »
Well looks like you have the work cut out for a long time
I know what I would do .in this case
The CB750F bike would be my choice
Lost track of all your plans for all the models ?
For the compression and HP and camshaft changes did not change till the 1977-78 model CB750F
where the head design changed .
Larger valves and cam change to more duration/lift and combustion chamber and domed pistons
I do have a 1977 CB750F ready to go if you loos interest in your project
Good luck
Honda Hansel
Honda Hansel
#1 1977 CB750 K7 #2 1981CX500C
#3 1982 CX500TC TURBO #4 2009 KAWASAKI KLX250
#5 2017 YAMAHA 1200 TENERE
#6 2020 KAWASAKI Z900 RS SE
#7 1978 HondaCB750F project bike
#8 1978 Honda CB550K
#9 1968 Kawasaki A1SS 250 cc Two stroke smoker
« Reply #5 on: March 18, 2025, 10:13:52 AM »
Jeff, thank you for the info, i was a bit worried about the brake pedal swap. Can you expand on what fabrication? I will be more inclined if i can modify the pedal and not the frame.
I agree, there is no appreciable performance benefit to the rear disc. And the complexity may not be worth it either. But i just feel it has an inherent "cool factor" I love the look of the rear disc on spoked wheels, and i also think moving the rear wheel and inch back might look cool as well. If i go for the rear disc, it will purely be for intangible reasons  :D It also largely depends on master cylinder/ brake pedal compatability though.
Good luck
Honda Hansel
Hansel, I'm a little disappointed to hear the performance improvements came 2 years later. However, the F engine i have has the best compression by a good margin, so I'll stick with it. Any idea if the K engines from 77-78 came with the same improvements?
I personally like the early K's best, the fork gators, raised gas caps, and 4-4 exhausts are drool worthy imo. I also own a CB550F so i guess i get my 4-1 fill there.
Thank you all for your interest. It might be a minute before this project starts in full as winter in Utah drags into March. The plan currently is to get a group of friends together and try to get the bulk of the work done in a weekend, bikes 2, 3, and 4 will be more or less slapped together. Bike 1 will be done more properly over time.
  • Sherwood Park AB
« Reply #6 on: March 18, 2025, 03:58:29 PM »
Hi
The 750F 1975-1976 use the same cam as the 1977 K7 and 1978K8
The 1977 F2 and 1978 F3 use a different cam and head
The part numbers are for the cam 14101 410 000.The head has 410 casting number and the pistons are domed and the combustion chamber is shaped different and the valves are bigger
The 410 out of the part number is 77-78 F bike classification
You can all ways go on CMSNL.com and look it up
that's where I all ways go to check for parts compatibility
Good luck
Honda Hansel
Honda Hansel
« Reply #7 on: March 19, 2025, 08:33:31 AM »
Sounds as if you have "1st World Problem", which bike to build and keep!  Obviously lots of options but first thought is build the K bike for the keeper and trash the K8 frame as it's toasted. Not worth the time building a bike with it.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #8 on: March 20, 2025, 06:01:30 AM »
how far over are the chopper forks?
i have a extra set of +8 forks but i would like another if you are willing to sell.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #9 on: March 20, 2025, 08:14:10 AM »
Hi
Good luck
Honda Hansel
Hansel, Thank you for the information. I hope some day I get to ride a 77-78 F to feel the difference. Same with the K0 as I hear they are also a bit faster.
a 1st world problem indeed, my first instinct is to build the F bike into a sidecar rig. I miss my 1994 Ural tourist, not for the rattly bucket of bolts that was the engine, but definitely for the side car. And the 3rd bike is the perfect candidate for a tracker build as it won't have an exhaust, side covers, seat, or tank that fits. But at the end of the day I don't need 3 CB750s when I already have 7 other bikes that desperately need my attention  ::)
I don't know what the ultimate fate of the twisted frame and siezed engine will be. I already tried soaking the siezed engine in WD-40 and seafoam for a couple months to no avail. For now the plan is just to make a really bad roller as it'll be easier to store.
They're long enough to make the center stand barley work, like teetering on one leg or the other. Right now neither fork leg has springs in them? the fork tubes are just so long that they bottom out in the fork bodies. Seems like a death wish to me. maybe you could add a spring and make them ~+8? I'm not sure, for some reason I took this photo, and only this photo, I believe that's a 12" harbor freight wrench for scale(see attachment).
If you are still interested let me know and I can get better measurements when I go to swap the forks out.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #10 on: March 20, 2025, 08:23:35 AM »
When ever you take some measurements lmk I'll prob scoop them from you!
« Reply #11 on: December 05, 2025, 03:51:48 AM »
Any progress on these projects?
« Reply #12 on: December 05, 2025, 10:28:39 AM »
Thanks for keeping me honest Stu, yes there has been a decent amount of progress, let me recount you the tales...
Let me just start by saying DON'T DO THIS, the compatibility issues between these bikes is one hell of a headache and it's better to just let each one be their own unique version. That being said maybe I can at least shed a little light on all of the various things I've found out.
The month is July, it's a Mild (for Utah's summer) 95F outside. I invited a couple of my friends over for what I was calling "CB750 Day". Previously in my driveway, this same group of people replaced the rear main seal in my friend's Bronco II so today was their turn to help me with my BS; what else are friends for after all.
The plan was simple: get the heavy lifting out of the way, and by that i mean 3 engine swaps, 3 fork swaps, and enough bolting back together to get everything to fit in the garage at the end of the day. I started work on tearing down my trusty K8 while my friends started work on the F. Things were going surprisingly smoothly for a while, not stripped bolts, no nasty surprises. One small issue was found with the F motor where the rear boss for the sprocket cover had be broken off, leaving only one bolt holding on the sprocket cover, someone must have lost a chain in the past.
After getting everything drained and unbolted from the K8 my friend and I attempted to heave the engine out of the frame and on to an engine stand(old office chair). However someone forgot to take the oil filter cover off... d'oh!
With that remedied, a conclusion was quickly drawn: my friend is a living engine hoist. What i thought would be a 2+ person job quickly tuned into a weight lifting exercise for my friend, who over the course of the day squatted all 6 engine transfers himself - what a legend.
Engine out of the K8, then put the F on the stand, yank the engine out of that, put the K8 engine in the F, move the K4 on to the stand, battle with the seized oil filter cover, yank the engine out of that, put the F motor in, roll it off the stand, put the K8 back on the stand and drop the K4 motor in that... round and round we went... what's the definition of insanity again?
Anyway, with all of the engines in their final homes I switched my attention to the forks as I saw that to be the second most intensive job for one person.
Here we go again: Forks off of the K8, on to the K4, K4's forks go to the K6(yes remember the poor K6?), K6 forks go onto the K8, F keep it's forks.
I only took one picture that day, the exposure is pretty terrible, but maybe you can get a sense of the chaos.
9 hours later (I'm actually surprised we got it all done in 9 hours) all the engines and forks had found their home and everything managed to fit in the garage.
On to the headaches now.
K8 exhaust system on a F motor in a K4 Frame? Bad Idea, the mounts in the back are not very similar, the K8 exhaust mounts by the passenger pegs, and the passenger peg mounting designs on the K8 and K4 are quite different. I think i will remedy this with some custom brackets (no chopping of anything original), but I certainly cannot recommend doing this. I would spring for an original K4 exhaust if it wouldn't cost more that most than all 4 of these bikes combined.
F chrome headlight bucket on K4 ears? looks kinda cool but the F bucket is shallower than the K4 bucket, leading to a bit of an akward gap, and on the inverse getting a K4 headlight bucket to fit on a F takes removing the blinker speaker and smashing the wires pretty good. I also can't recommend this but the chrome headlight bucket might be worth it.
F rear brake system on a K4, doesn't work at all, don't even try, the frames are way different to accommodate the master cylinder, and I don't even want to get into the rear wheel nonsense. Also the Master cylinder on my F might be too far gone, the Cir-clip holding in the piston is more rust than iron...
K8 sprockets on a F, actually okay, as long as you swap over the correct wider rear sprocket to the F hub then the chain seems to align just fine. This is very good as it could have ruined everything.
Other things that worked out: Gauges, most electrical components under the left side cover(fuse boxes vary), carbs and air-boxes switch over fine as long as you have the corresponding boots, F exhaust bolts up to a K8 engine just fine.
I know there's more but it's been a minute since I've worked on this.
I decided I would work on the F first because I knew I could get that one done to the point of selling without having to order too many parts. That looked a little something like:
hooking up the oil tank and hoses(forgot to tighten one fully, that was fun when adding oil), connecting the stator and points, installing all the second best electrical components, cleaning up some PO wiring(seems like most bikes need this), Installing controls on handlebars(It was missing the headlight switch side, i ended up using something from the parts bin that didn't have a headlight switch - oops), Oil filter and oil, Kick starter, rear sprocket from K8 than also chain from k8 (I'm a little sad to see this set of chain and sprockets go, it's a nice DID O-ring chain on hardened steel sunstar sprockets, it will probably outlive me.), Making the front brake work by cleaning out the master cylinder and working the caliper back and fourth(they could really both use a rebuild but I didn't want to spend the time or money), Cleaned up the carbs from the K4 thinking they were the ones from the F (first time using purple simple green and and ultrasonic via a suggestion on this forum - it works amazing! even better than chem dip!), Carbs on, airbox on, throttle tube and cables on, knock off petcock on the tank that immediately leaked(bike didn't come with the original).
Cranked this bike over and it fired right up... on 2 cylinders. The power feed for coil 2-3 must have gotten snagged at some point and was disconnected. After that it fired up and idled well! The tired old K8 engine is happy running in a F Chassis, sipping form K4 Carbs. It has no rear brake, and the front brake is far from adequate, but it was good enough to ride around the parking lot and post for sale. Here are some videos: https://immich.mikerts.com/share/2W17Bb-PFBqKubfhdQLLku8F5y8FR7DNiqHjfZFFb0crdGq9EwL-UtTiKUBmN93ZQjA
It's also for sale here if you live close to salt lake and want a CB750F project(don't judge the Chinese gator print seat too hard, i just had it laying around  ::) ): https://classifieds.ksl.com/listing/80246586
Next on the to do list for this project is to list the K6 for sale with whatever left over parts I don't want for the K4. I would make a runner out of this one too before selling but I can't get an exaust cheap enough to make it worth the time or effort. If someone wants to ship me the worst exhaust system they have for the price of shipping I would be grateful, you might just help put one more CB750 back on the road.
I also need to list the K8 for sale for scrap prices since it has a seized motor, twisted frame, and deathwish forks. (Grup if you want these chopper forks you're going to have to take the whole bike, I don't have another set to put in their stead - sorry)
And of course lastly I need to make my K4 nice, but for that I need to raise the funds first, it will need a lot including a whole new seat with pan, tires, brakes, title and registration, and a bunch of small stuff.
Always interested to hear what y'all think. I definitely wouldn't do this again, but in another light I am hopefully giving 3 of these bikes a new life they wouldn't have been able to have otherwise.
Offline rb550four
« Reply #13 on: December 05, 2025, 12:40:06 PM »
  I like the way you go about getting parts, it's a good story and I have taken the same path once or twice myself.
I understand that one machine may not fit all the parts where you need them or are missing parts where you want them for the bike you need to keep and you may or may not want to keep all but one of them....unless of course you decide to keep 2 of them and sell the others.
 Actually , with that in mind and your realistic low purchase price point habits( of less than $500 per unit) . It sounds to me that you could simplify the remaining initial parts mating issues....  the answer could be as simple as purchasing 4 or more 750's at the same low, low price or less per unit with the parts you need to complete the original 750 and quite possibly two or three others that you already own , that are nearly complete now, in which case, with just 2 or 3 more low, low payments of $500 or less, for up to but not limited to 4 additional models that could save you a lifetime of 750 Honda headaches that have been wrestling with for far too long.
 This has been a proven method  by many of our members time and time again over the years. Most members sign on as a machine owner but , some do sign on with one or two more. This proven method is almost guaranteed to fill your garage with every part that you may ever need for your original machine and countless others. You might not even be the first kid on the block to try this method, but once you do you may never go back... Just think , no more backing the car into the garage, it won't fit anymore, just think of the easibility of parking on the blacktop each and every night . No  more is the fear of wearing out those pesky garage door rollers from your cars rolling in and out twice a day, every day. And just think , that garage is finally is your domain, and yours alone...no one else will try to clean it, making finding those hard to find parts almost impossible to loose. This is the slice of heaven that all men and women have searched for over the ages. It's not for everyone, but it is for allot of us here, and we appreciate your story and look forward to how you handle these issues . Keep up the good work.
« Reply #14 on: December 05, 2025, 01:08:38 PM »
Thanks rb,
I, like you, am on a step 4 of a many step program.
A step in which i tell myself that selling this CB750 in order to buy a friends CB350 in order to sell my clapped out CL350 project is sound logic, and not the ramblings of a lunatic.
Also included in this step is being banned form looking at classifieds, unless of course it's to "cross reference" prices for listing my bikes  ::)
Maybe some day i can aspire to own 30 CB550s like yourself, for now however my garage is limiting, and i feel too bad parking them out in the cold - they always give me those puppy dog eyes.
« Reply #15 on: December 05, 2025, 03:01:24 PM »
Do you have a camera on me??
