As the subject indicates, my 1976 CD550Fss increases idle after its well warmed up. She is cold blooded at start-up, and needs a bit of throttle even with the choke on until a little heat builds. She runs well and very responsive to throttle inputs. [...]
This is normal behaviour for
all CB500/550s. The Owner Manuals give the right instructions.
The plugs indicate she's running on the rich side.
What part of the plugs? Only the ceramic noses can give you a clue. Realise that CB500/550 plugs with oldstyle Keihin carbs can foul quickly at idle.
All CB550
Fs have the oldstyle Keihin carbs. Consult the overview for standard settings.
Is the airfilter element clean? When the crankcase breather tube is attached to the airfilter case, the element may get humid by condens or even fouled by oil resulting in decreased air intake and performance. Keeping oil level maximum at half way between the upper and lower mark can be a remedy.
When all slow circuit components are clean, turning the airscrews will have an effect on the idle rpm. When you change
only one airscrew's position, it may be minor and hard to detect, but with
all four changed, change in rpm should be noticeable. It will take the engine at least 20 seconds to react. Realise that these pre 1977 models need a relatively rich idle to give a satisfactory acceleration (driveability). Leaning out the idle may result in an engine purring nicely like a kitten, but acceleration will be poor.
#32 slow jets are too small IMHO and they may get partially clogged when bike is not operated daily.
