Author Topic: No one makes a 520 front sprocket for a 1976 CB750F?  (Read 929 times)
Offline jmardy
« on: May 22, 2025, 08:26:34 PM »
I'm looking for a 17T front 520 pitch front sprocket and can't find one.
Cognito Moto make an offset one but I need a standard offset one.
Any ideas?
Re: No one makes a 520 front sprocket for a 1976 CB750F?
« Reply #1 on: May 22, 2025, 09:38:09 PM »
Any ideas?
Have you called Sprocket Specialists in UT. ?
1-800-782-8200
« Last Edit: May 22, 2025, 11:21:40 PM by grcamna2 »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: May 22, 2025, 09:39:21 PM »
1976 Z50A PARAKEET YELLOW
1971 CT70H CANDY TOPAZ ORANGE
1973 CL200 CANDY RIVIERA BLUE
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1976 CB750F CANDY ANTARES RED
« Reply #4 on: May 23, 2025, 02:15:26 PM »
Could just make a set….🤔
Take the difference off the inside of each sprocket to maintain original alignment..
And perhaps be a benefit when running an oversize rear tire with a chain guard…🤔
Offline pekingduck
« Reply #5 on: May 23, 2025, 04:13:21 PM »
520 sprockets are 1/8" narrower than 530.  Because front sprockets are hardened, you can't really turn them down - they have to be ground.  You could do it with an angle grinder, but would need to have the sprocket rotating while grinding for a uniform finish.
« Reply #6 on: May 23, 2025, 04:22:49 PM »
A ceramic insert will more than adequately cut the front sprocket, hardened or not…
An experienced machinist can probably do it with HSS and for sure with carbide…
« Reply #7 on: May 23, 2025, 07:01:43 PM »
Honda decided 530 wasnt strong enough and went 630 for the F2 so why go weaker, or do you enjoy welding crankcases
Offline jmardy
« Reply #8 on: May 23, 2025, 07:04:59 PM »
You’re really saying a modern 520 chain can’t handle the amazing torque of a SOHC 750?
My rear wheel doesn’t have a 530 sprocket option.
I’ll take my chances.
« Reply #9 on: May 23, 2025, 07:24:26 PM »
IIRC, Honda used the same spline on other models. I think the '79-'82 XR/XL 500s used a 520 chain, but I don't know if any 17 tooth sprockets were offered for the dual purpose bikes.
« Reply #11 on: May 23, 2025, 08:46:38 PM »
  Modern 520 chain sets are holding up on 200 HP bikes, chains have come a long way since the 1969 case breakers.
Offline jmardy
« Reply #12 on: May 29, 2025, 01:25:21 PM »
Thanks for the Sprocket Specialists referral.
Talked to Lance and he hooked me up!
« Reply #13 on: May 29, 2025, 02:23:12 PM »
I also recently ordered a 520 custom fr. sprocket.
I have a little Yamaha 250 that comes stock with a 530 Standard chain.
I want to go O-ring 520 and they had them.
