Author Topic: Ancient 400F gasket set.  (Read 453 times)
Offline Killer Canary
  • Typical Bran Muffin
« on: August 10, 2025, 01:02:55 PM »
I'm wondering if anyone knows if this was a quality name at one time.
I'm thinking that it must be; the gentleman pictured is even warning me to beware of imitators! How honourable is that? ;D
I just recently read on here about how newer head gaskets are too thick and will cause seeping of the oil control jets at the cylinder/head interface.
I'm hoping that these are old enough to have been made to the proper spec.
The best news is, I finally got around to replacing and reaming all eight guides so that they all have stem seals now.
I topped it all off with Kibblewhite seals and now for the first time since I've owned this bike, it doesn't smoke at all.
Small victories. :)
Kawi GPz900, H1
Offline Tim2005
Re: Ancient 400F gasket set.
« Reply #1 on: August 10, 2025, 02:20:25 PM »
Yes those were a good brand, that set is probably at least 20 years old. No idea about the thickness, but I suggest you get all the seals out of the packet and lay them out for a day or 2 so they can regain their original shapes
« Reply #2 on: August 10, 2025, 02:39:42 PM »
Yeah, that brand gaskets sets turn up NOS on eBay from time to time.   Have used them on Suzuki's.  Fit was good and no leaks.
« Reply #3 on: August 10, 2025, 02:51:02 PM »
That was most common maker used back in the 70's BUT i would still taket Hondamans advice about decking the bblock
