Author Topic: Jetting Advice for Modified 1971 CB750 K1  (Read 1518 times)
Re: Jetting Advice for Modified 1971 CB750 K1
« Reply #25 on: July 10, 2025, 09:11:50 PM »
Mark
I think you have a typo....
"More often in the 675A carbs (which are the normal ones for the K1)"
It should be 657A carbs, correct?
Oops, yep! Thanks! (fixed it)
It's my fault for not keeping tight watch on what this particular keyboard types. I got the laptop dirt cheap: if I turn it on from cold it works fine for about 15 minutes, and then the keyboard starts doing things like delaying one keystroke behind another, making all sorts of words and numbers up out of what I typed, and sometimes skipping halfway forward or backward through a paragraph to start typing up/down there instead(!). 'Tis a challenge (and time-consuming) to fix it all in my e-mails and forum posts, which is all I use this one for. After I put Linux on this one it stopped catching all the colds that my old Windows-based one did just from surfing the news.
And sometimes, I don't catch all the typos!  :P
« Reply #26 on: July 10, 2025, 09:35:07 PM »
However: if the plastic floats and current checkvalves came from 4into1.com, all these bets are off. Their checkvalves seem to weep constantly unless the fuel tap on the tank is shut off. Their floats are also undersized, not pushing the checkvalves closed very well. I received a "kit" from an owner (some 3 years ago, now) for his roundtop carbs (I was asked to rebuild them with supplied parts from 4into1.com) where one of the float valves was a differently sized (smaller) unit from the other three. It didn't fit the carbs, either.
Interesting! My floats and check valves are from 4into1, where do you suggest I get some better quality ones. I have had some issues with these in the past.
Did your carbs originally have the plastic floats, or the brass ones? There were some late 657A carbs that had plastic floats that I saw in the Fall of 1971, in bikes from the "new factory" at that time. My K2 that I bought new in 1/72, which came from Honda with a K1 engine, all built in 11/71, had brass floats in the 657A carbs (so, not ALL K2 bikes had 657B carbs, which the Internet is so sure about today). The brass-and-solder joints on those floats in 2 of the carbs got eaten away by MTBE during 1996-2001 here in Colorado, and I didn't ride it from 2001 until 2006 because of cancer. The floats were junk after that: then it received plastic floats when I refurbished it in 2006. Somehow all but 1 of the float valves survived that acid and are still in it today.
So, you can use the plastic Keihin floats in any of the roundtop carbs: I run them 1mm deeper than spec in the 657A carbs, but 26mm works OK in the 657B or 7A carbs (or the rarer 086a carbs). The 4into1 floats I have seen are too small and the geometry is odd where they shut off the float valve, making them have fuel-level troubles in the bowls (mostly it is too deep, uncontrollably so). I can look around in my [many] boxes of parts to see if I have 4 floats tomorrow, but I suggest getting float valves from PartsNmore.com or CB750Supply, those are the ones I rebuild these carbs with. If your carbs are the ones that have the tiny fuel filter on top of the float valves, I think Honda still sells them and PartsNmore.com has them from time to time in stock. They were found mostly in the 1975/6 CB750F1/2 bikes, but showed up in some of the late K5 and some of the K6 bikes, too (those with the 086a carbs). Those carbs usually had the idle-mix screws that stick out of the holes: they originally had little plastic "limiter" caps on the screws (emission controls), but those mostly disappeared by themselves by about 1985, just cracking and falling off from engine heat.
« Reply #27 on: July 10, 2025, 09:41:12 PM »
If there is any question about floats and valves, the actual fuel level in the float bowls should be verified with the "clear tube" method.
Offline KickstandDan
  • Young Buck
« Reply #28 on: July 10, 2025, 10:25:50 PM »
Mine originally came with plastic floats. The carbs have 7A stamped onto them. I still have them but with the 4into1 kit I thought the new stuff would work, but I see how the new stuff is not as precise or as calibrated as the stock stuff. Fortunately I kept everything I have removed from the bike.
I don't want a pickle. I just wanna ride on my motorcycle.
Offline TideWater2
« Reply #29 on: July 11, 2025, 04:54:03 AM »
Is there any documentation, frame #s or manufacture dates, on when each of the three carb jets were used?
Also, any identifiers for determining which factory made the bike?
2 - 1971 CB750 K1s
« Reply #30 on: July 11, 2025, 05:10:41 AM »
Not that I've seen 😕
  • Young Buck
« Reply #31 on: July 11, 2025, 06:42:29 AM »
This is what is stamped onto all 4 of my carbs.
« Reply #32 on: July 11, 2025, 07:36:54 AM »
Yamiya is also a good source of parts, high quality and of course, some high prices.
« Reply #33 on: July 11, 2025, 11:16:10 AM »
The "7A" designator, as far as I've been able to discover, indicated the new molds that were more precise that made the 657A series carb bodies: they are crisper renditions of the same carb. Those carbs appeared intermittently in the late K1, early K2, the K4, and F1 versions of the 750, based on the notes I've taken as I get to work on them (for decades). Honda had no defining literature on the 7A, but inside they look like more nicely-done 657A carbs. So, be cautious of the 'internet carb ninjas' who swear they know about the 7A carbs...
Float level for all 7A carbs with brass floats were 25mm and for plastic ones 26mm, as measured when disassembled: these are actual values I measured, not someone notes, "specs" or claims.
The jetting and needle setting rules for these follow the general settings for the year of the bike. In the K1 bikes with the 657A and 7A carbs made after 8/71 the mainjets were #110 with the needle clips in the 3rd notch (from the blunt top end) of the needles. This required, however, the use of the HM300 exhaust pipes: if the same carb was used in the later bikes with more restrictive pipes (K2 onward) the mainjet was normally #105 with the needle clip in the 4th notch. The 7A carbs came with plastic floats in the later bikes, too, except in the early F0 bikes when they were brass.
There are a few exceptions to this (including my own 750, a mix-and-match bike from rushed production in late 1972). For example, mine came with #110 mainjets and the needle clips in the 4th notch, using the AD125 spark advancer (very K1 early tuning) and an early K1 cam. It fouled sparkplugs in 500 miles, black as pitch, as it came from Honda. It also had brass floats in the carbs until MTBE ate them in the early 2000 era. (Now they are plastic.)
  • Young Buck
« Reply #34 on: July 11, 2025, 12:42:44 PM »
Wow that is super cool! Thank you for the information. Seeing as my bike has 9/71 on it we could assume that the carbs were possibly stock #110 mainjets and needle in the 3th notch. The mains that were in the carbs were 120 but that could have been my grandpa (who's bike this was originally) changed out?
I will see how 120 works on my freshly rebuilt bike after a few pulls and adjust accordingly.
« Reply #35 on: July 11, 2025, 09:12:53 PM »
Yeah, back "in the day" when some riders noticed that the K1 was "slower" than the K0, and Honda had reduced the mainjets because they also had changed the cam and the pipes (insides were different inside, particularly at the upswept bend), a LOT of riders ordered #120 mainjets and plugged them in, thinking they found the "secret" of the lost power. But, between the K0 and K1 the final-drive gearing (sprockets) had changed, the airbox had changed, the intake passages were slightly longer, and the cam was tamed a few degrees (as was the spark advancer, twice by the end of the K1) all to reduce sparkplug fouling and after-run on hot days (the mixture was so rich the bike wouldn't slow down immediately upon releasing the throttle on hot days).
There were lots of changes made between 1969 and 1971!
  • Young Buck
« Reply #36 on: July 11, 2025, 10:12:01 PM »
Wow, that is super cool. Thank you for the information. I have also really enjoyed reading your cb750 book so thank you for that as well!
Offline TideWater2
« Reply #37 on: July 12, 2025, 04:53:11 AM »
Thanks Hondaman, very interesting. I'm working on my 3rd K1 and still struggling getting the first one tuned as good as the second one. They are like women, they are the same, but still different.
2 - 1971 CB750 K1s
« Reply #38 on: July 12, 2025, 07:47:41 AM »
Tidewater, that is what I have found.  You can only get pretty close using documented carb settings with these bikes.  Although you may end up way off.  You may end up spot on.  The one thing you can count on is every cb750 is a littlle diferent.
« Reply #39 on: July 12, 2025, 07:52:49 AM »
And yet many are very obsessed with the early K0's.
For all their "faults" they take their place as important markers in motorcycle history
« Reply #40 on: July 12, 2025, 11:39:24 AM »
Boy, is THAT ever the truth now! :D
