Author Topic: CB350F dies when hot and coming off idle  (Read 1275 times)
Offline jpschroeder
« on: July 08, 2025, 05:42:53 PM »
Carbs were cleaned and synced ~7 months ago or so, timing is right, plugs are all firing. The engine starts up like a champ and drives just fine, but after the engine gets hot it starts to stutter when the throttle position is really low. This is true at high speed and at low speed, but after the engine is hot and the bike is still and in first gear, revving the throttle at all chokes the engine and it dies.
I'm pretty sure its rich in this condition, 3 reasons:
1. When I screw the air screws really far out (like 7 full turns) it seems to not be as bad, although its still there. At 7/8ths it dies reliably.
2. The exhaust smells rich, and looks rich.
3. The plugs are a bit sooty (not horrible, but sooty none the less).
To combat the richness, I set the floats a bit low. This didnt seem to have a significant effect. The jets are all original brass...but i wonder if I made a mistake cleaning the idle jets a few months ago because I used a needle (probably steel) and I'm suspecting it may have made the hole oversized.
HondaMan suggested it could be related to the orings on the primary jet being too small. The only thing I used from the carb rebuild kits were the orings and the ones on the primary were indeed pretty thin, but I don't have, nor have I heard anyone suggest anywhere I can get properly sized orings.
OK, let me throw one other thing into this mix. the bike has a 50k+ miles on it, and the cam chain tensioner is shot, it was shot when i bought it but not too noisy, and now its its rattling like crazy. I'm thinking I will have to tear the whole engine down to fix that too. So, I'm soliciting opinions, should I just bite the bullet and do all this at the same time, or try to get it running better before I start the rebuild — one less variable?
Offline newday777
Re: CB350F dies when hot and coming off idle
« Reply #1 on: July 08, 2025, 05:54:08 PM »
7 FULL Turns? No way
Stu
My current rides
Prior bikes....
Offline jpschroeder
« Reply #2 on: July 08, 2025, 09:06:36 PM »
7 sir, I kid you not!
« Reply #3 on: July 08, 2025, 09:30:40 PM »
If they are the same as 400 ask Nurse Julie a member here, she sell good O ring kits for 400,500 and 550
Offline Deltarider
  • I'm back
« Reply #4 on: July 09, 2025, 12:18:34 AM »
1. Is air intake free and unobstructed?
2. You may have reamed the slow jets. Do not poke anything in them that's harder than brass.
3. O-rings main jets need to be inspected to be sure. Pull and push them out and in. Do not 'screw' them in.
CB500K2-ED Excel black
Offline jpschroeder
« Reply #5 on: July 09, 2025, 08:28:11 AM »
1. Yes — new air filter, original airbox.
2. That would suck. Anyone have a source for OEM jets? I believe they are part number: 99124-286-0351
3. Going to see if I can replace these with ones from Honda Man
Offline M 750K6
« Reply #6 on: July 11, 2025, 04:17:14 PM »
Have you checked your choke adjustment, to be sure it's fully opening? Air filter blocked / incorrect? I had rich running from a Keyster brass kit on my 750. Went back to the originals.
Rich smell does point to carbs, but sometimes ignition: Weak coils / other ignition components, causing weak spark? Badly retarded ignition timing? Incorrect, fake or just poor plugs...
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #7 on: July 11, 2025, 08:11:27 PM »
Here is a great source for honds jets. They have slow jets #35 as well the part number for those is 99124-076-035
The number 99124-286-xxx is a slow jet part number for somthing else
These are Keihin Jets!
https://www.cmsnl.com/honda-cb350f-four-general-export_model14632/
« Last Edit: July 11, 2025, 08:56:28 PM by Ozzybud »
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline jpschroeder
« Reply #8 on: August 25, 2025, 09:17:56 AM »
I got new idle jets and installed them this weekend.
BTW — these are original OEM parts, and have the actual star K on them — everywhere that had "oem" parts when i messaged them admitted they were actually Keyster, except WeBike https://japan.webike.net/products/25690759.html — also the price was fantastic so for anyone looking for OEM jets, these were legit.
Long story short though, the new idle jets did not fix my issue coming off idle when the bike is hot (might have helped a bit). I think the next thing im going to do is the clear tube method for the carbs. Im 100% sure the floats are set right because I measured them so many times, but nothing else i can think of would be causing this rich symptom when hot.
Unless yall have other suggestions
« Reply #9 on: August 25, 2025, 12:37:24 PM »
Did I send you some O-rings for the mainjets?
Offline jpschroeder
« Reply #10 on: August 25, 2025, 12:40:06 PM »
You did HondaMan! THANK YOU. I actually installed them yesterday, sadly, they were actually a bit too thick and sheered when i tapped them in, so i had to go back to the too-thin ones. However, even though they are thin they do sit fairly snug, snug enough to not fall out if tipped upside down.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #11 on: August 25, 2025, 01:17:20 PM »
Did you use lubrication ( grease) when installing the jets? It's a must.
Offline jpschroeder
« Reply #12 on: August 25, 2025, 01:19:14 PM »
Sure did.
« Reply #13 on: August 25, 2025, 08:17:58 PM »
That's a good sign: it means those carbs were not damaged by the years of MTBE in our gas. In those carbs that suffered it, the O-rings I sent you are still too thin!
Online scottly
« Reply #14 on: August 25, 2025, 08:21:00 PM »
Yes, please do this test! :D
Offline jpschroeder
« Reply #15 on: August 26, 2025, 04:08:32 PM »
For the 350F how many mm below the top of the bowl should the fuel level be at?
Offline Deltarider
  • I'm back
