Author Topic: CB400f Minimum Piston to Valve Clearance  (Read 199 times)
Offline Tom R
« on: July 09, 2025, 08:55:29 PM »
Hi all.
I’m assembling a 400f motor I’m hoping to run in AHRMA vintage superbike lightweight…
Carrillo Rods, hd studs, CR26 carbs, ported head…
Kibblewhite valves and springs (new)… +1mm on the intake.
Megacycle race cam and custom Weisco pistons.
I installed the cam pretty close to straight up
The tightest I'm seeing is .058” on the intake, and .060” on the exhaust.
Too tight? What’s a safe redline on a build like this? 12k? 13k? [/img]
« Last Edit: July 09, 2025, 08:58:12 PM by Tom R »
CB750K5 - Slowly putting back together.
GS1100LT - Nicely upgraded over the years.
CB400F - Production lightweight race bike.
Cl175k7 - Gp200 race bike.
Re: CB400f Minimum Piston to Valve Clearance
« Reply #1 on: July 10, 2025, 05:24:22 AM »
I'd run about 65lbs of spring....Those clearances should be OK. Depending on your race schedule I'd change those springs out every 2 seasons....I have seen them lose a good amount of pressure. Brent Waller and others can testify to that too. ;)
Offline Tom R
« Reply #2 on: July 10, 2025, 07:29:21 AM »
Thanks Mike.
From memory, the kibblewhite springs are around 45lb?
Shims?
 -Tom
« Reply #3 on: July 10, 2025, 12:01:53 PM »
Thanks Mike.
Shims?
 -Tom
Yes Tom. You will need to use the OEM spring bases. The large shim is .060 thick if I remember correctly. 2 of those (which is all you can fit secondary to the height of the guide) and 2 or 3 small, inner shims. That should work unless the valves were sunk a lot during a valve job.
