Author Topic: CB750 K6 086A Carb Rack Shaft Sticks  (Read 3467 times)
Offline newday777
« on: July 16, 2025, 04:35:32 AM »
The Carb Rack shaft is very stiff to move the throttle lifts.
I've soaked it multiple times with brake cleaner, Carb cleaner and PB Blaster to no avail to free it up. Anyone run into this and found a good solution to fix it?? This is one of the few racks that has the right side idle screw mounts for the K5/K6 left side petcock so you can get to the idle adjustment screw.
I have other racks from earlier carbs that are very easy to move so I know there must be rust/corrosion in the rack boss that the throttle shaft goes through on this 086A rack.
« Last Edit: July 18, 2025, 04:06:23 AM by newday777 »
Stu
My current rides
Prior bikes....
Re: CB750 K6 Carb Rack Shaft Sticks
« Reply #1 on: July 16, 2025, 05:04:33 AM »
Try WD40
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: July 16, 2025, 05:10:12 AM »
Stu….. did it com to you in pieces? Could the shaft be slightly bent?
Offline newday777
« Reply #3 on: July 16, 2025, 05:15:09 AM »
No John, they were together. 086A carbs set.
 I'll put a straight edge on the rack later to check for bend.
« Last Edit: July 16, 2025, 05:26:58 AM by newday777 »
Stu
My current rides
Prior bikes....
« Reply #4 on: July 16, 2025, 05:40:15 AM »
You can strip the shaft right out BUT be carefull to remove any keys or pegs in the shaft before drifting out
Offline newday777
« Reply #5 on: July 16, 2025, 06:48:08 AM »
I've tried on another unsuccessfully.....unless you know of the technique
Stu
My current rides
Prior bikes....
Offline CycleRanger
  • No comment about being an
« Reply #6 on: July 16, 2025, 07:17:06 AM »
Try a little white grease.
Yes, taking the carb rack apart is not fun. It's very difficult to remove the roll pins.
Offline newday777
« Reply #7 on: July 16, 2025, 07:28:17 AM »
Where is the roll pins? There?
And how?
« Last Edit: July 16, 2025, 07:32:49 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #8 on: July 16, 2025, 07:36:14 AM »
And how?
I think I read somewhere they have to be drilled out, then tapped for a small bolt to go back together.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: July 16, 2025, 07:38:28 AM »
Not sure how the later racks were assembled but I had to strip mine down to free it up and remove corrosion. A little fiddly but I got it to work fine.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline newday777
« Reply #10 on: July 16, 2025, 07:48:27 AM »
I think the earlier racks are similar, they only had just the left side screw hole where as the K5/K6, F0/F1 have 2 screw holes, one for left or right side idle screw.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #11 on: July 16, 2025, 07:49:23 AM »
So how did you get the shaft out?
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #12 on: July 16, 2025, 08:37:30 AM »
Drill the pin and make sure it is all out or it will break the bronze bushing when you knock the shaft out. Been there, done that….
Offline CycleRanger
« Reply #13 on: July 16, 2025, 09:22:09 AM »
And how?
Sorry, you're right that's a solid pin.
I took apart a rack many years ago to replace a broken fork but I honestly don't remember now what method I used to remove that pin.
Offline Oly
« Reply #14 on: July 16, 2025, 09:54:02 AM »
Stu...Reference the following Hackaweek episode "73 Honda CB750 Custom Build Part 28 - Carburetor Install".
It shows how Dino replaced the pin that holds the rod in position.
1971 CB750 K1
1967 BSA 441 Victor
1966 Yamaha 250cc YDS3c Big Bear Scrambler
Offline newday777
« Reply #15 on: July 16, 2025, 09:55:39 AM »
I will thanks Oly
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #16 on: July 16, 2025, 01:12:48 PM »
Ok, because I couldn't remember I went and found my box of stay plate parts.
It appears that at some point they changed the stay plate design.
The one that I repaired secured the rod with a set screw covered by a staked-in aluminum cap.
That's how I was able to dismantle and repair my stay plate.
(Here's a couple of pix.)
I also have one just like yours with the pressed-in pin, it's got 086 carbs on it so I assume it's from a K6.
The stay plate with the pressed-in pin were clearly designed without disassembly in mind..
Sorry, I know that's not any help.
Offline newday777
« Reply #17 on: July 16, 2025, 01:19:26 PM »
Yes Oly and CR the videos and pictures helped to figure it out. I went through the carbs that I have and found the different caps to the pin of the K5/K6 iteration.
I haven't had time to drill it out yet as I was scheduled for some use of a friend's vapor Blaster, plus it's bike night. I'll get back to it in a couple days. Thanks much for all you do.
Stu
My current rides
Prior bikes....
« Reply #18 on: July 16, 2025, 08:49:58 PM »
I've done at least 2 of the K5/6 era racks with this little cover plate over a screw, underneath it. The cover plate was glued on and the screw's tip had collected quite a lot of grit, making the rod drag. The screw easily unscrewed, though, and I glued the little cover back onto it afterward with little damage. I used a small , sharp pick to get it off.
I've also seen them filled in with metal like Cerrobend instead of the cover. This melts out like low-temperature solder with either a soldering iron or propane torch, and I used ordinary solder to fill it in afterward.
The early racks (K1) sometimes just have pins in there, harder to remove those. Had to drill some of those, and then installed a roll pin afterward - with solder on top.
Offline newday777
« Reply #19 on: July 17, 2025, 03:08:26 PM »
Mark
The K6 086A, my 76 F0 064A, along with the late 7A(K5??) racks that I have ave all have the pressed in pins( and have double idle screw locations). The three 657B racks I have also have pressed in pins.
The early 7A K1 racks(2) and the 657A K2 rack that I have, have the staked caps and I figure they have the locator screw in them.
« Last Edit: July 17, 2025, 03:13:40 PM by newday777 »
Stu
My current rides
Prior bikes....
Offline Oly
« Reply #20 on: July 17, 2025, 03:13:48 PM »
Thanks for posing the question Stu,  CycleRanger for the pictures that sent me back to look at my carb stack project one more time and Hondaman's input related to the types of rod retaining devises used thru the years.
CycleRanger's picture of the retainer looked familiar and sure enough my 8/70 manuf'd K1 looked like it had the cap with a screw configuration.
Cap came off easily, unscrewed retainer, disassembled parts, replaced broken parts I received from John and it all went back no problems.
Thanks to all....
Sorry for hijacking your thread a little Stu!
1971 CB750 K1
1967 BSA 441 Victor
Offline newday777
« Reply #21 on: July 17, 2025, 03:32:46 PM »
Well I set up my 1/16" drill bit in the drill press, did a center punch mark in the center of the locator pin and slowly drill it, and watched it walk on me on an angle away from the pin center....Arg. Chucked in a 7/32" bit(smaller than 3mm pin size), put a wedge under the rack to try to get it to center, nope...it went at an angle also....ophhh. I'm thinking, now what??? We'll it didn't clear out the pin, but it did free up the action a bit. So I squirted in some LPS-1 greaseless lubricant(Mark's fix for corrosion in electrical connectors!) in the hole hoping that it would get in the groove and help. Yes it did! So I squirted more into the bearing surfaces on either side of the rack rod boss and worked it back and forth a bunch. I'm going to find a small set screw to fit in there to strengthen the remaining section of the pin, cap it and call it a win!
So thanks for all the replies and suggestions to get it freed up. Thankfully, I didn't have to try and remove the throttle rod to go further with it.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #22 on: July 17, 2025, 03:41:53 PM »
Thanks to all....
Oly that isn't a hyjack, as your information will probably help someone later that comes across it doing a search on finding an answer for their problem. I have some of the K1 and K2 racks of carbs that have the same cap and screw so hopefully they will continue to be good but now I know what to do if needed to take them apart.
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #23 on: July 17, 2025, 05:16:10 PM »
I knew my K5 had some K1 parts on it, like the side covers, but I didn't realize the stay plate had been changed since the carbs were 657B's.
I guess I lucked out when I got a replacement for parts because it had the set screw as well.
Offline newday777
« Reply #24 on: July 17, 2025, 05:24:12 PM »
Which side is your idle screw on?
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #25 on: July 17, 2025, 06:04:36 PM »
It's on the right but it could go on the left as well. That may be a consequence of swapping parts.
I also notice now that the slides are stuck.  :(  It's been sitting for a while because it needs the pucks replaced. Oh well.
Too many projects.
Offline newday777
« Reply #26 on: July 17, 2025, 06:36:25 PM »
Too many projects.
Thanks
What's the manufacture date of your K5?
My K5 is 7/74, so an early K5 and it came with 657B w/left side only idle screw rack.
Stu
My current rides
Prior bikes....
Offline CycleRanger
« Reply #27 on: July 17, 2025, 07:18:24 PM »
Too many projects.
Thanks
Mine is 12/74.
Offline newday777
« Reply #28 on: July 17, 2025, 07:26:26 PM »
Too many projects.
Thanks
Mine is 12/74.
As both of my friends who were the original and second owner have passed, I can't verify if my 657B carbs are original to my K5.
Stu
My current rides
Prior bikes....
Re: CB750 K6 086A Carb Rack Shaft Sticks
« Reply #29 on: July 18, 2025, 07:00:22 AM »
I have seen racks that have a cast in boss for the idle screw to be in either side, but only one side was drilled and tapped.  I don't remember what model 750 or carb casting number
Just thinking it might be easy to just drill and tap in certain carb swap situations.
« Last Edit: July 18, 2025, 07:02:21 AM by seanbarney41 »
« Reply #30 on: July 18, 2025, 09:36:59 AM »
Great save!
As Honda kept building the 750 and the margin got smaller (thanks largely to the Kawi 900 in those days) Honda kept pressing their vendors for lower prices. Having worked at building machinery for the Japanese between 1991 and 2005, this became a familiar pattern there, too. The vendors responded by installing pins instead of drilling/tapping/custom setscrews, among other things. You can "see" this all across each type of these bikes (750, 500, 550, etc.) when you work on all of them.
But, the pressed-pin racks, grrr...I think I have 2 of those in the "if I have to use them" box in the shed. My plan on that day would start with a MAPP gas torch on the pin's site, followed by freeze spray (or a douse in cold water) several times to see if the pin would work loose. The casting moves a lot more than the steel, which was why Honda didn't like pinned things, usually. I guess the combination of Yen supply, new 'hotshot' young engineers, and increasing competition pushed the production managers to pin some of the racks.
...end of rant...
Offline newday777
« Reply #31 on: July 22, 2025, 05:50:49 AM »
Thanks all. And yes Mark I was a bit dismayed when the bit wandered in the drill press, but joy returned when it loosened it's grip. I still haven't gotten around to getting a set screw in it, the four letter word keeps me out of the shop......have to be able to pay to get to play....
Stu
My current rides
Prior bikes....
« Reply #32 on: July 22, 2025, 05:26:11 PM »
I have a lathe and could turn down the end of a screw to make it a shaft-point, if you want to change it over? When I get a time to do something like that, I'll probably make 3 of them for the 2 in my shed, and any others out there.
Offline newday777
« Reply #33 on: July 22, 2025, 05:40:06 PM »
Thanks but there is still enough meat in the pin holding the assembly that I think all it needs is a short set screw to hold what is left solid.
Stu
My current rides
Prior bikes....
