I made a die from a piece of sharpened tubing to punch out the big hole over the small hole.
I might be in the twilight zone myself, but out of 4 sets, I never found early carbs that had any top gaskets in them until I put them in myself, including a 7,000 mile sandcast.
Be very careful with the threads when you put the tops back on, the threads are fine and the metal is soft and the spring wants to hold the top plate off center. The gasket uses up some of the thread area.
