Author Topic: I cannot find earl 750 carb top gaskets anywhere!  (Read 1089 times)
Offline slyguy
« on: July 21, 2025, 01:37:05 PM »
It’s like I’m in the twilight zone?? Early 1970 1-4 cable- “top gaskets” I thought I had them with Honda-16171-275-004 but the center hole is too small!?
Re: I cannot find earl 750 carb top gaskets anywhere!
« Reply #2 on: July 21, 2025, 02:48:10 PM »
 I made a die from a piece of sharpened tubing to punch out the big hole over the small hole.
 I might be in the twilight zone myself, but out of 4 sets, I never found early carbs that had any top gaskets in them until I put them in myself, including a 7,000 mile sandcast.
 Be very careful with the threads when you put the tops back on, the threads are fine and the metal is soft and the spring wants to hold the top plate off center. The gasket uses up some of the thread area.
« Last Edit: July 21, 2025, 02:54:27 PM by Don R »
Offline slyguy
« Reply #3 on: July 21, 2025, 02:53:01 PM »
Yes Don, that’s what we are doing next :) The link posted won’t work, the hole is way too small.
« Reply #4 on: July 21, 2025, 03:18:46 PM »
Message JamesH on this forum. He sells perfect ones he has made.also sells gorgeous replica carb clamps.
Offline Pbeattie89
« Reply #5 on: July 21, 2025, 05:33:23 PM »
4into1 has them but only as a kit.
 https://4into1.com/carburetor-repair-kits-complete-set-honda-cb750k-1969-1971/
Sent from my SM-G991W using Tapatalk
Offline CycleRanger
  • No comment about being an
« Reply #6 on: July 21, 2025, 06:07:57 PM »
CMSNL has these.
https://www.cmsnl.com/honda-cb750k0-four-1969-usa_model20233/washer-top_16110300004/
Also Honda still sells that packing kit.
16010-300-014
« Last Edit: July 21, 2025, 06:10:15 PM by CycleRanger »
Offline slyguy
« Reply #7 on: July 21, 2025, 07:34:00 PM »
Thanks I’ll check it out👍
yea that looks right in the pic, I’ll have to measure the caps for minimum hole size & then call them if possible.
« Last Edit: July 21, 2025, 07:38:12 PM by slyguy »
« Reply #8 on: July 21, 2025, 08:14:04 PM »
4into1 doesn't have a phone listed..
Offline JamesH
« Reply #9 on: July 22, 2025, 01:36:58 AM »
I still have a few sets of these - made from fibre-reinforced Nitrile and laser cut to an original pattern. Drop me a pm on here.
Offline JamesH
« Reply #10 on: July 22, 2025, 01:40:19 AM »
Shown here with a set of #28 carb tops
« Reply #11 on: July 22, 2025, 08:30:10 AM »
I used these (and a set on James’ carb clamps) on my S/C project and they are perfect!
« Last Edit: July 22, 2025, 08:32:31 AM by BenelliSEI »
