Author Topic: Decent replacement horns  (Read 876 times)
Offline toomanybikes
« on: August 11, 2025, 03:45:42 AM »
Seems like both horns on my '78 750F are toast. Running 12v directly from a battery does nothing.
Most of the horns on Amazon are now super cheap, small, and have the connectors in the wrong orientation with no way to rotate the mounting tab.
Are there any aftermarket replacement horns that are roughly the same size and will work with the existing mounting bracket and wiring? Looking on ebay, Honda seems to have used the same horn with the '90's CB750 as well.
current stable, always subject to change ...
'22 MG V85TT
'19 Triumph Scrambler XC
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
Offline CycleRanger
  • No comment about being an
Re: Decent replacement horns
« Reply #2 on: August 11, 2025, 07:32:50 AM »
Sometimes moisture gets in there and the diaphragm gets stuck.
The earlier horns could be taken apart but that one looks crimped.
That screw is is sort of a volume adjustment. You might try running it in and out a couple of times. It might unstick the horn. Might.
« Last Edit: August 11, 2025, 09:33:20 AM by CycleRanger »
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: August 11, 2025, 08:05:46 AM »
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_185_96&products_id=479
Says sold out but these may work. Japan is on holiday now but might be worth checking
1973 CB 750 K3
10/72 build Z1 Kawasaki
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #5 on: August 12, 2025, 10:51:18 AM »
My CB750 K6 got dual snail horn for safety. They wake up bad car drivers.
Cheap chinese stuff still working after 10 years. A relay is needed.  Bike parked in warm dry garage when not ridden.
Something like these
https://ebay.us/m/Z0XtxZ
Offline Deltarider
« Reply #6 on: August 13, 2025, 02:48:41 AM »
Voxbell horns are a true classic and were standard in the 50s and 60s on many Lancia's and Alfa Romeo's. Moto Guzzi also had them. It has a wonderful sound (115dB). I would describe the sound as 'class and distinction'. The set draws 10A, so you need a relay and a separate 15A fuse. When I bought them, they were quite cheap. They have this nice sound you would hear on Alpine roads back then. Looks nice too. They were quite easy to fit once I had bent two brackets myself. They are a joy and I feel safer.
« Last Edit: August 13, 2025, 02:51:20 AM by Deltarider »
CB500K2-ED Excel black
« Reply #7 on: August 13, 2025, 03:41:12 AM »
Thanks all. I'm going to give these a try https://www.amazon.com/dp/B0CM42KP49?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Benefits are:
1. Same diameter as OWM
2. Mounting tab is bolt on in rear, so I'll be able to rotate or replace wit the OEM tab to get proper position. I'll post a pic if they are successful
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #8 on: August 13, 2025, 06:32:34 AM »
Fiamm was always the go to in the 70's in uk, wake the dead with those
« Reply #9 on: August 13, 2025, 09:12:39 AM »
Thanks all. I'm going to give these a try ...
I prolly have an OEM spare if you want to go that route.
« Reply #10 on: August 13, 2025, 02:35:54 PM »
Thanks, I'll let you know how the aftermarket ones work out.
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
« Reply #11 on: August 13, 2025, 02:57:18 PM »
I put this narva "fanfare" set on years ago I hate squeaky horns,I left the red plastic covers off though,not expensive at all.
« Reply #12 on: August 15, 2025, 04:14:46 AM »
For posterity, these Neoget horns seem to be decent replacements. The mounting tabs are the right size and can be rotated to the best position. The connectors can be bent to a decent position and didn't snap. They fit with the existing plastic parts, etc. They are a little deeper than OEM, so they stick out a little further, but it's OK. A two-pack is under $20 on Amazon, at the moment.
« Last Edit: August 15, 2025, 04:17:31 AM by toomanybikes »
'22 MG V85TT
'10 BMW R1200 RT
'81 Honda GL1100
'78 Honda CB750F SS
