Author Topic: Getting back to work on my K1  (Read 4094 times)
Offline Tinman
« on: September 16, 2025, 03:21:09 PM »
   I've been doing rust removal on my gas tank, this like many sat for thirty plus years,it looked like napalm inside. I've used vinegar from the grocery store, I'm pretty happy with the results, it's now getting a final treatment of evaporust. I'm sure I'll have to coat it when I'm done. I've been a member for 15 years but haven't posted much but will be now that I'm set up to work on this bike. Tinman
Tinman
Re: Getting back to work on my K1
« Reply #1 on: September 16, 2025, 03:22:22 PM »
Go, Tinman!
Great start: my first 1971 750 had that same tank.
« Reply #2 on: September 16, 2025, 03:43:44 PM »
Welcome back! If it doesn’t leak, don’t coat it.
« Reply #3 on: September 16, 2025, 04:22:44 PM »
   "final treatment of evaporust. I'm sure I'll have to coat it when I'm done.  Tinman
Like the Tinman.....use oil to treat the tank, 2 stroke oil works well.
Offline pickleknuckles
« Reply #4 on: September 16, 2025, 10:37:18 PM »
Makes me want another even more
Sent from my Pixel 8 Pro using Tapatalk
« Reply #5 on: September 17, 2025, 07:19:03 AM »
   ....looked like napalm inside.
"I love the smell of Napalm in the morning!"
                              - Lieutenant Colonel Bill Kilgore
« Reply #6 on: September 17, 2025, 07:49:13 AM »
"Smells like victory"
Agreed, if it does not leak, don't line it with anything.
More photos?
Offline Dr. Frankenstein
« Reply #7 on: September 17, 2025, 10:17:34 AM »
"...that smell...that gasoline smell..."
"Don't get off the boat."
Great movie!
« Last Edit: September 17, 2025, 10:19:42 AM by Dr. Frankenstein »
Offline Tinman
« Reply #8 on: September 18, 2025, 07:32:07 PM »
Thanks gentlemen, the motor spins, about 120 lbs psi per cylinder. I'm cleaning the carbs, thank god for ultrasonic cleaners but they still need lots of manual labor. I do have spare coils from my two '76,'78 super sport bikes which I'm going to part out.
Tinman
Offline Kevin D
  • SE Michigan
« Reply #9 on: September 19, 2025, 06:40:55 AM »
Tinman, my own CB was stored for 15 years 1987-2002 with 2 inches of gasoline in the tank, my biggest mistake. I put hardware in the tank and shook it, rinsed it, repeated until clean. I got a new screen in the petcock. No sealer.
 Fresh gas and new battery and the bike started right up. Tank didnt leak. That screen is so fine it caught some debris in the bowl but it never got plugged. After a season of riding, there was just a tiny bit of debris in the bottom of the bowl. No leaks.
 Since then, the tank has been good for 20+ years 60,000 miles. It got a repaint in 2007 and came back better than new.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Tinman
« Reply #10 on: September 19, 2025, 07:27:42 AM »
Kevin, I think that's the next thing I'm going to do, I've seen someone on YT that's done just that. Thanks
Tinman
« Reply #11 on: September 19, 2025, 08:03:11 AM »
Pictures!!
Offline Kevin D
  • SE Michigan
« Reply #12 on: September 20, 2025, 12:06:56 PM »
The very early work that I did has no photos, sorry, just faded memories: there were a couple brass floats that were bad, replaced with plastic. A float valve or two, 5.5 mm fuel lines. I didn’t want to spring for a repaint for a bike that was no good but the bike was good and the repaint was terrific.
 A barbecue rotisserie was the preferred means to agitate the tank with hardware inside, I didn’t have one.
Lining the clothes drier with foam and giving your tank a spin was another means, I didn’t do that.
And I haven’t told you that I used a media blaster inside the tank, don’t do it.
I got a bunch of counter sunk wood screws with lots of sharp edges and put them in the tank and shook it until I couldn’t. I emptied the screws and the crud, rinsed till clean, repeated with screws and flush until no more crud.
 The paint was badly faded, there were knee rubs on the tank, the side covers were cracked.
Lots here that didnt “survive” , but the tank did.
« Last Edit: September 20, 2025, 12:38:45 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Online PeWe
« Reply #13 on: September 21, 2025, 10:15:49 PM »
That color is really nice, Kevin.
So you still use stock side covers?
I thought they all become brittle and crack at removal due to age.
Offline Kevin D
  • SE Michigan
« Reply #14 on: September 22, 2025, 04:49:13 AM »
The original side covers both cracked and were badly faded.
The reproduction replacements came from David Silver, LPM brand? Unpainted.
New grommets to hold them and much gentler handling these days.
The paint was mixed by a local guy as his side job.
DonDirtBiker Vintage Honda Paint, no longer in business.
It was applied by a friend/coworker Jim Nicholson, who did a masterful job.
Sadly, Jim has passed on.
« Last Edit: September 28, 2025, 05:21:33 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Offline Tinman
« Reply #15 on: September 22, 2025, 04:39:21 PM »
Kevin, thanks for the pics and tips for fixing the tank, here is a couple more pics of mine.
Tinman
« Reply #16 on: September 22, 2025, 05:00:13 PM »
Online Mark1976
« Reply #17 on: September 22, 2025, 05:13:36 PM »
   That tanks going to need some serious attention...
Start with the end in mind...
« Reply #18 on: September 27, 2025, 07:07:39 PM »
I've got several sets from FrankenFrankenStuff (in these forums). They are better than Honda's, with stronger and more resilient mounting tabs. First-rate parts!
Online PeWe
« Reply #19 on: September 28, 2025, 12:20:44 AM »
I ordered my side covers from Yamiya because they look like stock Honda ;D Maybe better plastic.
Painted and not painted.
Online PeWe
« Reply #20 on: September 28, 2025, 12:36:58 AM »
That tank looks very rusty.
Finding a better tank can be a better and in the end cheaper choice.
Painting the tank cost some, then find leaks means a waste of money, time and effort.
I do not trust liners either. Worth a try if tank looks really good on outside in stock or other good paint but has deep rust inside.
