Author Topic: How Do I Adjust The Choke? 1977 CB550  (Read 619 times)
Offline UFOwasaband
« on: October 08, 2025, 04:34:14 PM »
How do I adjust the choke here?  I do not have a handlebar control for it.
1977 CB550.
Offline jaytee-nz
Re: How Do I Adjust The Choke? 1977 CB550
« Reply #1 on: October 08, 2025, 10:47:19 PM »
What do you mean by "adjust" ?
To synchronize the choke flap openings between each carb so that each carb gets an equal amount of "choking", the carbs need to be removed and the flaps adjusted by the screws / locknuts.
If you mean, how do you put the choke on, simply lift up the leaver in the picture to start the bike and push it back down once the engine begins to warm up.
Offline Bodi
« Reply #2 on: October 09, 2025, 08:21:40 AM »
Yes, what do you mean?
The choke is that lever marked "choke". Up is fully closed, down is no choke, in between is partial choke. These carbs do not have the throttle cam to add throttle with the choke so you have to work the throttle to keep the engine running at first
The lever directly works the carb it's on, there are adjustable linkages between the throats to synchronize the plate movements. I try to have them all flat to the airflow at full off, whatever closed angle they end up at is OK they don't all have to completely close but I don't want any restriction at full open.
« Reply #3 on: October 09, 2025, 08:47:15 AM »
The big question is WHAT MODEL BIKE, 77 550 does not narrow it down enough
Offline CycleRanger
  • No comment about being an
« Reply #4 on: October 09, 2025, 09:02:28 AM »
This is the choke lever. There is no handlebar control.
Consult the owners manual for use.
You can download a PDF for your bike here:
Offline UFOwasaband
« Reply #5 on: October 09, 2025, 04:01:47 PM »
Just want to be sure the choke mechanism is set up right.
I know how to use a choke.  LOLZ.
1977 Honda CB550 Super Sport.
Offline Bodi
« Reply #6 on: October 09, 2025, 07:08:09 PM »
Looks perfect. But can't see any of the plates. If you had the bodies off, the linkages have to be correct. If you haven't disassembled them most likely all is well.
Offline CycleRanger
« Reply #7 on: October 11, 2025, 11:10:11 AM »
Sorry, I misunderstood what you were asking.
