Author Topic: drilled handlebars  (Read 328 times)
Offline crashmaster
  • 1972 CB 750 K2
drilled handlebars
« on: November 23, 2025, 05:03:33 PM »
I want some lower handlebars so I look cool.  :P Was thinking satin black, but I don't see alot of pics of them. Should i try to get the bars drilled with the OEM holes? Thanks
Online Don R
Re: drilled handlebars
« Reply #1 on: November 23, 2025, 05:22:25 PM »
 If your bike came with the wires inside, drilled ones makes sense. Otherwise, you have to modify the controls to route the wires outside. Also, the bars carry a ground for some circuits, so paint or powder coat might be an issue.
Offline crashmaster
  • 1972 CB 750 K2
« Reply #2 on: November 23, 2025, 05:30:34 PM »
Thanks Don. Just talking with my son looking at pics online. I think chrome would be better anyway. Lots of black up front already. I think Euro bars are close to what I want.
« Reply #3 on: November 24, 2025, 07:14:01 AM »
Euro bars are good and 400F bars are popular as well...
Offline carnivorous chicken
« Reply #4 on: November 24, 2025, 07:26:42 AM »
If you are going to drill the bars, you've got to be careful. First, the wiring for the switches is 50 years old and can be brittle. You can always lube it with something to make it slide in and through better, and I tie something like fishing line to the end to route that through the bars first to make it easier. You've also got to file down the inner and outer edges of the bars to make sure that when you route the wiring it doesn't cut the housing.
I've done both -- threading and notching the switch housing to route the wires externally. The latter is much easier, the former looks better...
« Reply #5 on: November 24, 2025, 08:05:25 AM »
You didn't say what bike you were putting the bars on. That is always helpful for finding what you want and is helpful for others later on that find your thread doing a web search or forum search.
As to wires inside the bars, yes you will need to verify the edges inside especially have been smoothed off, no sharp edges to cut the sheath or wires.
A heat gun is your friend on getting the wire loom out of the bars and back in another set. Heat the bars up to soften the sheath(it's hard and brittle holding folds and bends after all this time. The when putting it back in, I take a piece of  new wire with a hook bent in and carefully tape it to the end of the loom to add a little pull power to get it in as you carefully guide the other end in the hole
heat the sheath so it is soft again. Yes a little dialectic grease helps too.
I have the euro bars on my K5 750 and like the stance for my back and the look. You will need to get shorter cables and brake hose too.
« Reply #6 on: November 24, 2025, 09:35:24 AM »
One comment
DO NOT drill undrilled bars, Honda reinforced the bars where the wires come out and i have seen b ordinary bars break where that hoe was made
Offline crashmaster
  • 1972 CB 750 K2
« Reply #7 on: November 24, 2025, 10:35:15 AM »
Thanks guys. Its for a CB 750 K2
Offline crashmaster
  • 1972 CB 750 K2
« Reply #8 on: November 24, 2025, 10:39:18 AM »
The reading I did on the Euro bars seem to say that I would not need to use shorter cables? Curious what other people's experience has been.
Online Don R
« Reply #9 on: November 24, 2025, 11:11:59 AM »
 I've used shorter length cables on a cb750 with cb400F bars, I think the K1 euro bars I got from DSS were a little wider and ok with a little re-routing of the stock cables.  They were my favorites, although I sold that bike.
« Reply #10 on: November 24, 2025, 11:12:17 AM »
You may not "need" to but the Euro bikes with these bars have a diff part number.
More info here, see reply #16...
http://forums.sohc4.net/index.php/topic,163005.msg1877159.html#msg1877159
« Reply #11 on: November 24, 2025, 11:27:51 AM »
I've gotten away without replacing cables, just a little different routing. Throttle cables, for example, with a little bend forward before they go back toward the carbs...
Offline crashmaster
  • 1972 CB 750 K2
« Reply #12 on: November 24, 2025, 03:09:15 PM »
Don, I assume DSS is David Silver Spares? Never ordered from them - I assumed shipping would be really expensive? Looks like maybe it's out of stock when I looked for it.
 I found these - https://carpyscaferacers.com/shop/shop-our-store/hot-rod-parts-accessories/steering-hot-rod-parts-accessories/handle-tracker-chrome/ - but it's not drilled
https://www.ebay.com/itm/231077188475
https://vintagecb750.com/collections/handlebars/products/handlebar-stock-type-cb750k-1972
https://www.classicbikeshop.co.uk/honda-cb550f-super-sport-handlebars-1975-76.html - these are 550 bars from UK
Thanks for all the great tips guys! If anyone has suggestions I am all ears
« Last Edit: November 24, 2025, 03:17:34 PM by crashmaster »
« Reply #13 on: November 24, 2025, 03:23:40 PM »
DSS has a US warehouse as well so shipping should not be too bad
Offline crashmaster
  • 1972 CB 750 K2
« Reply #14 on: November 24, 2025, 04:11:42 PM »
That's good news - I did not know that!
Offline crashmaster
  • 1972 CB 750 K2
« Reply #15 on: November 24, 2025, 05:05:11 PM »
what is the difference between the Honda Euro bars - part number 53100-300-610, and the bars that are part number 53100-341-000? I see the numbers interchanged on some sites
« Reply #16 on: November 25, 2025, 06:54:34 AM »
Here is their U.S. website...
https://www.davidsilverspares.com/parts/by-model/
Offline crashmaster
  • 1972 CB 750 K2
« Reply #17 on: November 25, 2025, 08:04:46 AM »
Thanks Stev-o. I emailed them and that bar won't be back in stock until the middle of next year
« Reply #18 on: November 25, 2025, 08:35:46 AM »
Offline crashmaster
  • 1972 CB 750 K2
« Reply #19 on: November 25, 2025, 10:16:50 AM »
Yeah that's the one I'm leaning towards right now. Or the one on Vintage cb750.com that I put a link to earlier in this post. I think they have free shipping
Offline low-side
« Reply #20 on: November 25, 2025, 06:01:17 PM »
If you can't find drilled bars and don't mind changing your controls, GL1000 switch gear routes the wires outside the bars and still has a "period" look.
