Author Topic: oil filter thread  (Read 211 times)
oil filter thread
« on: January 13, 2026, 12:41:41 AM »
just out of interest heres a pair of filters I have on hand,Ive never used a ryco one on the honda but are a big aussie brand here,use em all the time on cars,I thought Ide take a closer look at them,the ryco has more pleats,but the internal slots look more restrictive and there also seems to be a wide seam join with no slots in it,the MIW ones Ive used before,dont see how its multi stage?has less pleats but I think a better internal free flowing steel centre compared to the ryco?the ryco might filter better but hamper flow?itll need a proper set up pressure flow test to find out,I tried blocking one end and blowing through them both couldnt tell any difference.
« Last Edit: January 13, 2026, 12:46:20 AM by dave500 »
Re: oil filter thread
« Reply #1 on: January 13, 2026, 12:45:10 AM »
Might be the pic but they look different sizes.
As you should be changing it every 1500 miles is it going to make a difference, I know Honda say 3,000 but i have never believed in putting clean oil, change at 1500, through a used filter
« Reply #2 on: January 13, 2026, 12:48:22 AM »
yeah the phone photo makes em look way different,here I have em sitting on a flashlight,see the internal cage.
« Last Edit: January 13, 2026, 12:52:13 AM by dave500 »
« Reply #3 on: January 13, 2026, 01:16:00 AM »
If engine has an oil pressure gauge, a difference might be seen depending on the oil filter.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: January 13, 2026, 06:44:46 AM »
Imagine the size of the paper media, stretched out on a flat surface. They are so large that I suspect the flow rate would be virtually identical?
