Author Topic: Fork lowers length - help please  (Read 611 times)
Offline Nasher
« on: February 21, 2026, 05:21:30 AM »
Hi,
My Honda RC181 replica has unknown fork lowers - the base bike is a 1972 Honda CB500 Four
Standard CB500 fork lowers are slightly shorter
Attached are pictures showing measurements
Can anyone please help identify model/part number of my fork lowers (stanchions are 35mm diameter)
Thanks in advance for any assistance
Online newday777
Re: Fork lowers length - help please
« Reply #1 on: February 21, 2026, 05:43:07 AM »
Do yours have 341 stamp on them?
« Reply #2 on: February 21, 2026, 06:19:49 AM »
If both sides have disc caliper mounts could be 550
Online newday777
« Reply #3 on: February 21, 2026, 07:26:48 AM »
The 550 uses the 341 lowers(same as 750) 14" length top of case to bottom of the bolt)
BTW 341 is stamped on the back side behind the brake mount plate.
I don't have any CB500 forks to measure, the parts fiche say they use a different part number than the 550.
« Last Edit: February 21, 2026, 07:29:45 AM by newday777 »
Online newday777
« Reply #4 on: February 21, 2026, 07:28:03 AM »
K7/K8 use a longer case that measures the same as your picture above
« Reply #5 on: February 21, 2026, 09:45:37 AM »
500 has one plain slider and look shorter but never measured them
Offline jonda500
« Reply #6 on: February 21, 2026, 05:19:29 PM »
My 750/550(341's) and 500 fork bottoms both measure 12.5" from the top to the bottom of the cases not including the end caps or studs...
John
A starter clutch thread:
Offline Nasher
« Reply #7 on: February 26, 2026, 03:27:43 AM »
Firstly,  thanks to everyone for taking the time and effort to reply - much appreciated, im sorry for my belated reply
[/quote]7
I've checked and there are no stampings
 Yes, they do have mounts on both sides
[/quote]
Yippeeeeeeeeeeeeeeeeee - you're a star!
Honda CB750 K7/8 it is
Once again, thanks to everyone
« Last Edit: February 26, 2026, 03:35:29 AM by Nasher »
« Reply #8 on: February 28, 2026, 11:42:42 PM »
 750 F0 and F1 also use that fork case.
Offline Nasher
« Reply #9 on: March 01, 2026, 10:40:31 AM »
Thank you
