Author Topic: CB750 cam chain guide interchangeability?  (Read 134 times)
Don R and 3 Guests are viewing this topic.
Offline 02z06dave
« on: March 27, 2026, 08:14:27 PM »
I am in the rebuild process of a 1970 k0 right now. I ordered a new cam chain guide without really thinking about it and got the later style guide. Is it ok to use the later guide in the k0 engine or do I need to order the early guide?
Online PeWe
Re: CB750 cam chain guide interchangeability?
« Reply #1 on: March 28, 2026, 12:19:51 AM »
I have used the later (taller) with K1 cyl and head.
You might need to file a little to widen the upper part of cam chain tunnel where it will stick up. The mold is not square.
I had to do that on K6 heads that must have been shipped with the earlier, shorter.
The pins on the glider it hangs with are thicker on the later. Less rattling sound.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #2 on: March 28, 2026, 07:47:02 AM »
I never thought about this before.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline 02z06dave
« Reply #3 on: March 28, 2026, 08:28:29 AM »
Thanks. I have test fitted it and it seems like there are no problems. But I didn't want a problem that I don't foresee
« Reply #4 on: March 28, 2026, 09:07:57 AM »
Normally if a newer part wont replace an older one Honda will keep both in production and change some of the part number
Offline 02z06dave
« Reply #5 on: March 29, 2026, 10:16:47 AM »
I don't know if that rule wpuld necessarily apply in this case because the older part wad also used on the CB350. Ot could have been kept in production for that model in particular
« Reply #6 on: March 29, 2026, 07:56:38 PM »
In those early sandcast/K0 engines with the shorter camchain guide, the chain makes a slight 'jump' to the upper sprocket in some of the later heads if the newer guide is used: I ran into this (the opposite way) with a sandcast engine when I tried to drop in the newer guide - just because I had it on hand at the time. The guide's top seemed like it was too far forward by a little bit (like only 1-2mm of distance difference) so the chain would deflect when entering the top of the guide. When I got the 'correct' shorter guide it sat slightly further toward the rear of the engine, and the line of the chain from the front of the cam sprocket was a straight-down shot, no deflection at the top of the guide.
So, I think the later guides might be slightly offset toward the front of the engine via their locating pin boss(es), and/or the cam's bearings similarly in the head? I don't have a sandcast head to go measure, but that's my hypothesis at the moment? I have a K0 head from a near-sandcast engine (like 80 past the sandcast era) somewhere around here, might have to go see if I can find it, now that I'm a-wonderin'...
