Author Topic: Interesting Bead Blasting Experience  (Read 1437 times)
Offline SD750F
    • My Business Site
« on: April 24, 2007, 06:11:58 PM »
I am going to look into this situation that happen to me tonight. I was bead blasting with medium fine (100-130) glass beads some aluminum parts in my blasting cabinet and when I was done I decided to bead blast my custom wedding band made from high grade titanium. It was looking like the wear that 10 years of marriage can do... ;)
I userstood why I was seeing the sparks that were generated, but the static electricity that was generated on a fairly high humidity day was amazing! I was shocked through my rubber gloves as well as were the cabinet touch my legs... Wow didn't expect that when I was getting no effect from the aluminum.
I am sure it is nothing more than duplicating the action of a simple Van De Graaf generator... But I was truly amazed by the large static potential generated by only the titanium.
Scott
Offline Steve F
Re: Interesting Bead Blasting Experience
« Reply #1 on: April 24, 2007, 07:17:58 PM »
Scott
One of the worst things to do while blasting is to hold the object where you're blasting the glove with a strong stream of media.  As you stated, a static build-up is created.  Just keep your arm in CONSTANT contact with the blast cabinet while blasting, and you won't build up a static charge.  Your body is like a giant capacitor, storing the static charge and just waiting for the potential to find a ground, and ...........ZAP!
Isn't titanium and magnesium cool to bead blast???   ;D  Some carbides do the same thing, only not so pronounced.
Offline SD750F
    • My Business Site
« Reply #2 on: April 24, 2007, 07:55:55 PM »
That was my gut physics feel for the situation. I was acting like the static pick-up inside a Van De Graaf generator. I was seeing if anyone else has similar experiences.
And by the way, my ring looks like new again...
Scott
Offline 74cb750
« Reply #3 on: April 25, 2007, 09:53:46 AM »
Can we call you Captain Zap! now?
Laugh at least once a day.
Life  $ucks, then you die.
Offline SD750F
    • My Business Site
« Reply #4 on: April 25, 2007, 11:50:52 AM »
Oh great! I have a nick name....
 ;D
Scott
