Author Topic: newly installed Dyna S and rain don't agree  (Read 1568 times)
nuke
« on: April 28, 2007, 06:01:54 AM »
installed ignition and coils a few weeks ago(78cb750F2), and this morning I got caught in the rain. A few clicks into the rain and the bike went on what felt like 2 cylinders. Now could ANY exposed wire (in the new ignition system) cause this malfunction? ??? What am I looking for? I'm assuming that the problem is in my new electrical work cause I never had a problem in the rain before, not that I saw alot :D may be getting in somewhere else?
Any info or past exp. with rain and  ???  would be appreciated
thanks
 :) ;) :D ;D >:( :( :o 8) ??? ::) :P :-[ :-X :-\ :-* :'(
nuke
« Last Edit: April 28, 2007, 06:04:02 AM by nuke »
Re: newly installed Dyna S and rain don't agree
« Reply #1 on: April 28, 2007, 06:03:58 AM »
Probably the connections at the coil HT wires
Offline jaknight
  • ....Round Town Ride......
« Reply #2 on: April 28, 2007, 07:36:42 AM »
Hi nuke,
     Yes, I would check connections at coils; I have a Dyna S on my '74 cb750 K4 and I have ridden in hard rain many, many times and many, many miles.
     Never had a problem with my Dyna S; feet did get a might cold...... ;) ;)
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline anparkinson
« Reply #3 on: April 28, 2007, 01:30:34 PM »
Check the points cover - the cork gasket is pretty useless. I seal mine with silicon when I put it on and it stays dry. It used to lose a couple of cylinders for a few minutes even going through a puddle before I did that.
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #4 on: April 28, 2007, 02:35:01 PM »
Don't ignore the connection at the plug end.  Some fill the wire ends with dielectric grease and then push onto the plugs to keep water out.
I ran a CB650 points cover (cast aluminum) on my 550, and did my last motorcycle course on it in 2 solid 8 hour riding days in pouring rain.  Points/condensers and no problems.  No gasket, no silicone.
nuke
« Reply #5 on: April 28, 2007, 04:05:02 PM »
thanks for all the help guys, I'll check all the above mentioned and see what happens. It looks like rain for the next few days and I have to ride into work. (wife needs car)  :( I'll let you know what happens.
nuke
