Author Topic: Which Chain Guards will Fit?  (Read 1976 times)
Offline DrMark
« on: April 06, 2005, 07:08:28 AM »
GM, I would like to upgrade the chain guard to a CHROME version on my 1978 CB550. Which ones will fit (without modifications)?
If mods are needed, I see the 550F version attached near the rear sprocket cover...does it use the sprocket cover/plate bolts?
1978 CB550K
1983 CB650SC Nighthawk
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
Re: Which Chain Guards will Fit?
« Reply #1 on: May 26, 2005, 05:45:43 AM »
This is what I was able to discern from the greenspun archives.
Any of the K-series guards all the way through the model run should fit.  The F's are different - however, while they won't fit a K exactly, you can swap chain guards on any F with another F guard regardless of the year.
