Author Topic: Blowout scared the crap out of me  (Read 1600 times)
Offline Rsnip988
« on: June 26, 2007, 05:34:08 AM »
Tube Blowout scared the crap out of me
I wa test riding yestarday to make sure i had properly fixed the charging system when the bike started handling funny i hit the brakes and the rear started to slide out to the right and i got it back unbder control  finally got it stopped and trucked it back home, but dang it was frightening to think of what could have happened had i been going faster than 55
any advice on where to get a "cheap" 18" 110/90 tube fast
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
eldar
Re: Blowout scared the crap out of me
« Reply #1 on: June 26, 2007, 06:36:28 AM »
Well I dont know what you mean by cheap but most tubes are under $10 and even I can afford that with how broke I am after bills.
Offline Rsnip988
« Reply #2 on: June 26, 2007, 10:24:36 AM »
my local place has the 110/90 18" tubes for $11.98 so i'll do that,
i didnt know what the cost was sothats why i said cheap at first
is there a way to remove the rear wheel without "breaking/opening" the chain? I've never done the rear before so i dont know how long it may take to do
thanks for the reply eldar
R.K.S.
1976 CB750 K6 Full
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: June 26, 2007, 10:41:16 AM »
Don't need to break the chain.
Just get it off the sprocket. Wheel comes out.
No.
eldar
« Reply #4 on: June 26, 2007, 01:31:33 PM »
Yup. Move wheel forward and pull chain off the outside. Pull axle bolt out and off the wheel should come.
Offline Rsnip988
« Reply #5 on: June 27, 2007, 01:34:19 AM »
thanks much, I will try it when I get home
when replacing a tube do you need to replace the "rim cover" (rubber that covers the nipples to protect the tube) or is it just preformed as needed, the local shop has the tubes in stock but only has 17" an 19" nipple covers he said the 17 can be stretched or the 19 could be cut to fit, i'd lean toward stretching myself
any thoughts?
R.K.S.
1976 CB750 K6 Full
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #6 on: June 27, 2007, 03:33:19 AM »
You only need to replace the rim tape if the old one is past it's best, if it still looks in good shape keep it
1978 CB550 K3
1985 H100S
« Reply #7 on: June 27, 2007, 05:08:47 AM »
To remove rear wheel pull the front sprocket to loosen chain and then remove chain from rear sprocket to let wheel slip out easily (after unbolting everything else). When putting wheel back on just reverse procedure and slide wheel in, put chain over rear sprocket, push wheel as far forward as it will go and put chain on front sprocket and mount front sprocket. Easy!
Good luck,
Andy
eldar
« Reply #8 on: June 27, 2007, 06:53:27 AM »
As CrisP said, only replace the rim strip if the rubber is getting bad. Otherwise there is no need to worry about it.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #9 on: June 27, 2007, 08:53:16 AM »
Good inner tubes are still inexpensive. Treat the bike to a 'name' brand like a Michelin....
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
« Reply #10 on: June 27, 2007, 09:33:21 AM »
You can re-use the rim strip rubber if it still feels like rubber.  But, do look underneath it for rust on the rim.  I had one go down and the rust has built a spire that grew through the rim strip and the tube.  I cleaned off the rust, painted with real zinc chromate and it's be fine ever since done, 10 years ago.
Buffo
« Reply #11 on: June 28, 2007, 07:10:16 AM »
Cheap...Hmm....I usually get concerned when i hear people use the word "cheap" when it pertains to tires, tubes and break parts...but that may be irrational...
You could get rid of the tube all together and fill your tire with sand...it would never go flat
Offline nickjtc
« Reply #12 on: June 28, 2007, 08:25:02 AM »
Back only a few days and already cuttingly incisive!!
1977 Suzuki GS750
Offline Rsnip988
« Reply #13 on: June 28, 2007, 10:07:53 AM »
true but i'd like it to actually handle better than a ton of sand
R.K.S.
1976 CB750 K6 Full
bobsmith
« Reply #14 on: June 29, 2007, 01:04:40 PM »
I sure understand the "pucker power " of getting a blowout at speed..its happened to me 2 times and will definatly ruin a good pair of fruit of the looms. As for the rim n tube  I wire brush and paint mine, along with a strip of duct tape under the spoke rubber. Buy a quality name brand tube...the cheap ones may hold up fine, but do you want to experement to save $5.00?
Offline Rsnip988
« Reply #15 on: June 29, 2007, 02:35:54 PM »
i got it off the bike easier than i thought i could, but getting the tire half off of the rim took about an hour, a lot of yelling, a near sprained finger and 2 prybars, but i got it in there and blew it back up good as new, also added air to the front as i noticed it only had 28psi instead of the 40psi the tire says it needs
thanks all for the help
now help me with the "air fuel mixture thread problem"
http://www.sohc4.us/forums/index.php?topic=23583.0
 ;D  thanks again
RKS
R.K.S.
1976 CB750 K6 Full
Offline sandcastcb750
« Reply #16 on: June 29, 2007, 03:12:20 PM »
how about those Chinese tires?? After the news, I would think twice about using them on two wheels.
« Reply #17 on: June 29, 2007, 03:31:51 PM »
Word to the wise.  The PSI rating printed on the tire is the max load rating tire pressure.  Not the expected running pressure.  Were I you, I'd back the pressure down between 30 and 35, watch the tire wear and adjust accordingly.
The 750F owners manual says that with the bike at full capacity; 32 PSI front and 40 PSI rear.
Vehicle capacity load limit is 360 Lbs.
« Last Edit: June 30, 2007, 09:39:17 AM by TwoTired »
Offline ElCheapo
    • Anubis Cycle
« Reply #18 on: June 29, 2007, 05:26:23 PM »
Vehical capacity load limit is 360 Lbs.
So much for me packing a lunch to go with on a ride  :D
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
