Author Topic: Dumbo question approaching - exhaust gaskets  (Read 2627 times)
Offline pae
    • Phil Edwards CB650 pages
« on: July 08, 2007, 12:21:41 PM »
Forgive me, but my only experience has been with dismantling my 650Z, so when new parts arrive in the post they don't necessarily look anything like the bit I took off due to PO's changing bits, or puttting things together wrong, or whatever. OK excuses over.
In my gasket set there are 4 rings that look like a felt or wadding material wrapped with a gold wire. Now they are (obviously?) exhaust gaskets. Question is, there was nothing like these that came out when I removed the old exhaust, just a copper ring (in fact 2 copper rings on some ports!!!)
I like the look of these felt gaskets, but is that all I need? Or do you use copper ones? As well, or instead?
Sorry, might seem a dumb question, but I can only go by what came off when I pulled it apart. And it weren't these little babies.
thanks for your help, Phil
'79 CB650  .... | ....  XJ600 electric drag racer  .... | ....  T W M C
It takes a lot of practice to sound like yourself
Offline Bodi
Re: Dumbo question approaching - exhaust gaskets
« Reply #1 on: July 08, 2007, 01:39:21 PM »
There is an amazing variety of exhaust gasket types. The original ones had an asbestos core I think and, asbestos being a hazardous material now, they aren't made that way any more. If the ones you have fit in the ports OK then use them, I've had obviously wrong sized ones come with gasket kits. Make sure you get all the old ones out - it is not unusual to find more than 2 in a port.
Offline 333
  • Time for change
« Reply #2 on: July 08, 2007, 03:48:02 PM »
And what you describe as "felt" probably is asbestos.  An old gasket kit on the shelf is probably the reason.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 736cc
« Reply #3 on: July 08, 2007, 08:17:37 PM »
Sometimes the oem gaskets are so sooty and squished you can't see them in the head. A skinny screwdriver carefuly punches them out of that black hole.
Offline pae
« Reply #4 on: July 09, 2007, 09:54:39 AM »
Are the gaskets black? Some manufacturers are using felt like carbon fiber gasket material. I believe the advantage is that they withstand heat better and don't shrink.
Here's one of 'em...
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #5 on: July 09, 2007, 10:25:24 AM »
Looks more like a c&%k ring than a gasket if you ask me ;D
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #6 on: July 09, 2007, 02:48:34 PM »
An asbestos c&%k ring! Now that's some quality S&M. :D
I'll bet those are old asbestos exhaust gaskets. Wear gloves and a respirator when installing them!
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Ibsen
« Reply #7 on: July 09, 2007, 04:29:44 PM »
That is the same exhaust gaskets that came in the stock Honda gasket set I bought for the 650 from David Silver, and they do work as long as you have removed the old gaskets. You can skip them and buy copper gaskets instead. I think the 44mm copper gaskets will fit.
« Last Edit: July 09, 2007, 05:11:53 PM by Ibsen »
Offline 736cc
« Reply #8 on: July 09, 2007, 04:34:42 PM »
that exhaust looks loud, how would you tell if it was leaking? The diameter is bigger than the intake!
what? say again, I didn't hear ya
Offline Jugghead
  • I just THINK I'm a
  • 350cc of pure FUN
« Reply #9 on: July 09, 2007, 04:45:02 PM »
haha, no offence, but are you kidding? a hazmat setup for four rings? :D
asbestos is most dangerous when in very fine particulate form that can enter and deposit in your lungs.
otherwise, these rings are "mostly harmless" unless you live in California, where everything is cancerous or dangerous.
9/72 CB350F...15k miles and rising
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #10 on: July 09, 2007, 05:30:34 PM »
haha, no offense, but are you kidding? a hazmat setup for four rings? :D
None taken, I was kidding. :P
Quote from: Gordon
Offline svenD
« Reply #11 on: July 09, 2007, 05:35:45 PM »
just testing ! ::)
