Author Topic: Emgo Pods on 550  (Read 5274 times)
danjwsu
Emgo Pods on 550
« on: July 21, 2007, 01:46:27 PM »
I've got a 74 cb550 and I just got some emgo air pods.  They dont fit between  the carb and the frame on the outside carbs.  Has anyone made these work with this problem.  I dont know if I can put some angle tube and bring them out the side.  I want to stay with these pods, since I already paid for them.  Any help would be great.  Thanks
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: Emgo Pods on 550
« Reply #1 on: July 21, 2007, 08:15:42 PM »
I know there was a special model(tiny) that I ordered for my 71 CB500 from crc.
http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
It doesn't look like that link will take you to the page though so go to fuel system parts > air filters > pod filters.  It'll be the first one in the list.
The K&N pods that came on my 72 500 were just crammed in there crushing the element a little.  Make sure your carbs and rubbers are in as far as they'll go because there isn't much clearance even with the small ones.  When I put mine on, I didn't think they would go initially, but with a little massaging they went on and have about 1/4" or 3/8" clearance from the frame.
1977 CB750
relative q
« Reply #2 on: July 21, 2007, 09:07:21 PM »
I got my Emgo pods to fit my 77 550F by putting the two outer ones on pieces of car radiator hose and piping I picked up at the local auto parts store and clamping everything down.  Not the cleanest looking thing, but so far it's worked without a problem.  Eventually I think I'll try to find some that actually fit.
danjwsu
« Reply #3 on: July 22, 2007, 08:35:51 AM »
I thought about using a 45 angle pvc pipe piece to bring the filters out the side but am not sure if the tank/seat/side covers will hit it.  Any more ideas?
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: July 22, 2007, 08:42:04 AM »
Seems like adding extra length to the intakes on two of the carbs would cause those two cylinders to run differently than the others.  I don't know exactly how much of a difference it will make, but you should really have the intakes on all four carbs the same length.
Offline dustyc
  • 1977 CB750K
« Reply #5 on: July 23, 2007, 11:00:18 AM »
Here are the pics I said I'd post inthe PM.  Hope they help.
I crammed the K&N in to show how that fit.
1977 CB750
danjwsu
« Reply #6 on: July 23, 2007, 01:03:08 PM »
Is there any way you could measure the pods that fit from top to the end of the rubber boot.  They seem to look real good.  Thanks
Offline dustyc
  • 1977 CB750K
« Reply #7 on: July 23, 2007, 01:19:11 PM »
1977 CB750
danjwsu
« Reply #8 on: July 23, 2007, 10:19:21 PM »
Thanks for all your help.  I'm ordering the smaller ones tonight.  You just saved me a lot of time, cursing, and money.  Thanks again
danjwsu
« Reply #9 on: July 26, 2007, 09:32:33 PM »
Just put the smaller pods on tonight.  They look great and actually fit.  And to top it off, I was finally ready to fire the old girl up for the first time in about 6 months ;D.  Sounds great and seems to run good.  I still dont have my wheels done so it will be a few weeks untill I can ride her and see how much the pods and pipe did.  Thanks for all your help
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: July 26, 2007, 09:36:51 PM »
Did you already re-jet the carbs to compensate for the pods and new exhaust?
danjwsu
« Reply #11 on: July 27, 2007, 07:28:27 AM »
[/quote]
Nnot yet.  I want to ride it first and see where its lagging.  I'll probably ove up to a 110 or 116
