Author Topic: Running on 2  (Read 1472 times)
Grohidighast
Running on 2
« on: August 16, 2007, 06:59:53 PM »
What are some things to check for when its running on 2?
I know its not the coils, I switched them, and the same 2 ran.
Thanks
Offline aptech77
Re: Running on 2
« Reply #1 on: August 16, 2007, 07:02:30 PM »
OK....cuz it's a twin??
What?? More info!
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
Re: Running on 2
« Reply #2 on: August 16, 2007, 07:46:29 PM »
Thanks
Did you check the plugs?  Fouled plugs could be the cause.
Sparty
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: Running on 2
« Reply #3 on: August 16, 2007, 08:29:34 PM »
If it's 1&4 or 2&3, one set of points or condenser or connectors along the way.
If it's 1&2 or 3&4, one set of carbs not getting gas.
« Last Edit: August 16, 2007, 11:09:29 PM by dustyc »
1977 CB750
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
Re: Running on 2
« Reply #4 on: August 17, 2007, 12:19:10 AM »
Oh, yeah....  sometimes I forget that motorcycles other than 4's exist.
75 cb750.
I'll check the plugs first thing tomorrow.
It backfires on the two that aren't running, so I think it might be running lean.
I'm also going to check the seal of the carb boots, and the air screw.
Thanks for the help so far guys.
make sure to check those damn points, too :) I can't count the number of times I've been bit by points.
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline Shenanigans
  • Right turn?
Re: Running on 2
« Reply #5 on: August 17, 2007, 12:46:44 AM »
Are you using that Dyna S yet?
Offline dustyc
  • 1977 CB750K
Re: Running on 2
« Reply #6 on: August 17, 2007, 02:29:10 AM »
Make sure the plug wires aren't reversed for those cylinders.  Which 2 aren't firing?
1977 CB750
Offline aptech77
Re: Running on 2
« Reply #7 on: August 17, 2007, 06:50:15 PM »
Backfiring? I would look at timing or ignition problems.
