Author Topic: Where does this clip go.....  (Read 1132 times)
Offline Patrick
« on: October 04, 2007, 10:11:57 AM »
I'm putting the oil pan back on my K0 750. One of the bolts is supposed to hold a wire holder for the wire harness from the neutral switch. I stupidly didn't mark the position when I pulled the bolts. Can anyone tell me which bolt I'm supposed to put this on?
As always, thanks in advance.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline UnCrash
  • Pass
    • My Blog
Re: Where does this clip go.....
« Reply #1 on: October 04, 2007, 10:16:38 AM »
On my 78, the wire remains attached underneath when you take off the pan.  You should be able to just locate the hole near the wire....
Then again I probably don't know what I'm talking about on a K0
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: October 04, 2007, 10:24:16 AM »
 It goes on the bolt right next to the drain plug on the later bikes. I'd assume it's the same for K0 but not sure.
Offline Patrick
« Reply #3 on: October 04, 2007, 11:32:38 AM »
That looks right, Scondon. Thanks for the help, guys.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
