Author Topic: gas cap thumb latch 72 cb500  (Read 1630 times)
Saylor
« on: November 07, 2007, 11:52:20 AM »
trying to find a new thumb latch for a 72 cb500 gas tank (no key). I just bought a nice looking tank but it came with a broken latch. Ive been trying to find this small part without any luck. If anyone has a lead I'd appreciate it.  Thanks
Offline Rock Store
  • Real Cafe Racers are Mechanical canvases of art !
    • http://www.geocities.com/when_pigs_fly_mc/
Re: gas cap thumb latch 72 cb500
« Reply #1 on: November 07, 2007, 11:58:35 AM »
Saylor ,Otherv than Ebay and other sources,Honda is real good on maintaing NOS parts in japan for older models,as a matter of fact they take pride in parts availablity.Give your local Dealer a call.Later..RS
Rock Stores current machines, Modified 1993Ducati 900SS,1978 Tracy 550K! Past machines way to many to list & well missed,Dunstalls ,Ducatis & the like.
Offline mkramer1121
« Reply #2 on: November 07, 2007, 12:27:01 PM »
The thumb latch was superseded due to them popping open in crashes.  Your only hope is probably ebay.
Offline Kevin D
  • SE Michigan
« Reply #3 on: November 07, 2007, 05:27:07 PM »
Wow....heres a new one at Yamiya..........$100.00
http://www.yamiya750e.com/catalog/product_info.php?products_id=655
oops this is for 750... formerly unobtanium.... same part for 500??
« Last Edit: November 07, 2007, 05:38:55 PM by Kevin D »
71 CB750 K1
106,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: November 07, 2007, 06:18:27 PM »
Yipes! I guess my latch doesn't look as bad as I thought.
« Reply #5 on: November 07, 2007, 09:32:15 PM »
Previous poster was correct as Honda supply only the locking type, which is a 400 four part but fits all the external cap sohc 4 and any key (or screwdriver) fits
« Reply #6 on: November 07, 2007, 10:10:10 PM »
I sorta hate to admit,
 but...along time ago, mine did that.
I somehow drilled out the end of the pin, that the latch catches ( Dont remember how i drilled but may have held the headed end with vise grips or pliers) To open cap I push down taking pressure off the pin and pull it out..usually hold in my teeth while refilling..put it on the bike you will loose it.
 Fill your tank insert pin push latch forward press cap down till it catches.. done.. crude but works... and looks like it is still ok..
okie
« Reply #7 on: November 08, 2007, 04:53:06 AM »
I have one of those latches somewhere on my workbench.  PM me with shipping info and it is yours.  Do you need the spring and pin too?
Saylor
« Reply #8 on: November 08, 2007, 07:27:58 AM »
Thanks Everyone for all the Suggestions.
 And thanks for the Yamia tip, Great source.
