Author Topic: CB500 caliper/piston - is it good enough? UPDATED PICS  (Read 3029 times)
Offline dkruitz
    • Dan's Antique Outboard site
« on: December 17, 2007, 05:54:19 AM »
Just got the stuck piston out of the caliper body - never had one of these apart before.  There are a couple of pinholes of corrosion on the piston, but I think I can smooth them down with 2000-grit wet/dry, same for the bore.  For certain none of the pinholes are big enough to cover the spread of the seal.  I also removed seal and cleaned the aluminum corrosion from the groove.  Rubber seal is flexible and seems decent - should I reuse it, or are these always replaced?  Can post pics if needed.
« Last Edit: December 18, 2007, 07:31:36 AM by dkruitz »
Offline bozo4onion
Re: CB500 caliper/piston - is it good enough?
« Reply #1 on: December 17, 2007, 06:02:48 AM »
I just got a seal. Cheap (<$10) and Honda still makes them. Change that thing.
« Reply #2 on: December 17, 2007, 06:28:49 AM »
Change the seal, post a pic of the piston
Offline hymodyne
« Reply #3 on: December 17, 2007, 06:57:17 AM »
I cleaned up an original piston in my first rebuild of the 500K1 in my avatar. 250 miles into a 350 ride with a friend through MA and VT, I noticed a lot of heat coming up from the rotor and that my  mileage had fallen off really badly. I discovered when I got home that my "fixed-up" piston ( I had sanded and polished out the pitted parts) had basically gotten stuck each time that i braked. IMHO, I'd drop the cash for the new piston, or the phenolic ones that are advertized on ebay. good brakes are worth the money...
hym
"All things are ready if our minds be so."
« Reply #4 on: December 17, 2007, 07:51:36 AM »
hym..were you using the adjuster bolt?? i take them out
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: December 17, 2007, 07:53:11 AM »
You mean you run the front brake without the adjuster bolt fitted?
Fully floating?
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
« Reply #6 on: December 17, 2007, 08:27:44 AM »
Always..
Offline hymodyne
« Reply #7 on: December 17, 2007, 09:53:33 AM »
my bolt was in place. I thought it was necessary to get the proper clearance of the puck to the disc, per the shop manual...somebody talk to me as to whether I need them or not; I'm going to a set of 550 forks and dual discs in January, right after I get married... ;D
hym
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: December 17, 2007, 11:41:45 AM »
I'm with Steve. Honda seemed to think they served a purpose. Why do you run without it?
Offline dkruitz
« Reply #9 on: December 17, 2007, 07:24:07 PM »
OK, I've got a photo, but it's not very good.  Between the resolution of my camera, and the focus distance, you can really get enough detail I don't think.
« Reply #10 on: December 17, 2007, 08:29:56 PM »
These were the first disc brakes used on a stock bike, not a lot of experiece behind them...
 Run the bolt if you will but, do a tire change on dual disc once, then tell me what you think..
« Reply #11 on: December 17, 2007, 10:11:41 PM »
picture not good, need one of just piston where pits are
Offline dkruitz
« Reply #12 on: December 18, 2007, 06:54:05 AM »
OK, I just took this with a much better camera - no flash used so the exposure is long and about as still as I can hold the camera.
The caliper body looks really discolored, but it's smooth.  Only thing I've done to any of this is clean it with brake cleaner, and scrape the seal grove out carefully.
The photo is at http://www.elginoutboard.com/caliperbig.jpg  if you need to see the fullsized image, as I believe the board shrinks it down.
Offline dusterdude
« Reply #13 on: December 18, 2007, 07:19:21 AM »
my opinion is,if the piston is smooth and there are no burrs from the pits,i would run it,it doesnt look that bad to me.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
  • I'm back
Re: CB500 caliper/piston - is it good enough? UPDATED PICS
« Reply #14 on: December 18, 2007, 08:33:20 AM »
That piston is O.K.
Offline dkruitz
« Reply #15 on: December 18, 2007, 11:06:36 AM »
Thanks guys, I'm going to "polish" it lightly with some 2000wet/dry to be sure nothing is protruding, and see about a new seal.
Offline edbikerii
    • Gallery
« Reply #16 on: December 18, 2007, 01:02:14 PM »
That piston looks practically brand new compared to the one I've been running since the early '90s!
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
« Reply #17 on: December 18, 2007, 08:11:04 PM »
OK piston is useable at present but will get worse and new ones can still be got at the moment but will get scarcer---your call
Still looks to be a bit of crud in the groove needs to be really clean, fit new seal lubed with brake fluid WEAR GLOVES; polish piston with finest wet and dry available (2,000 grade is good) using brake fluid as a lube and making sure there are NO raised edges on the pits Clean off ALL the crap and relube and assemble.
If you have a freind in a machine shop and can get some 1 1/2 inch (38mm)stainless for him to bore out you can make a piston
