We used to use this stuff back in the UK printing industry and it is nasty stuff! The fumes are quite literally, lethal in an enclosed space. You don't want to get it on your skin, either and it will lift paint in a New York minute. The NGA (print union) banned it, and while it was very good at what it did, just wasn't worth the associated risks.
There are lots of solvents and substances that are nasty, dangerous, or bad for you. Actetone, for example, will dissolve many substances. Your skin is NOT an impermeable membrane! Acetone, MEK, etc will dissolve material (oils, glues, etc) and drag it right into your body and into your bloodstream through your skin through osmosis. Your kidneys and liver have to try and clean your blood and can be damaged by what you've absorbed through your skin.
There are many chemical fumes that will kill you when concentrated in and enclosed space. Your lungs transfer these fumes into your bloodstream along with, or in place of, atmospheric oxygen. Gasoline, ammonia, alcohol, etc. are all lethal when misused. Banning is NOT a cure! Banning is a solution for the ignorant. Education and training works far better than a bureaucratic measure, IMHO. You cannot live your life free of all chemicals. Learn to use the ones available, safely.
