Author Topic: Maiden voyage, disaster!!  (Read 2410 times)
Offline CB750R
  • 77 CB750F
« on: August 02, 2005, 11:33:43 PM »
well, after triple checking the timing, and valve clearances, assuring that proper oil flow was getting to the head, I took the old girl out for a ride, nice and mellow, kept it under 5grand, no faster than 100km. but steady at 80 for most the time, all of a sudden it sounded like a grinding gear, so I pulled in the clutch and coasted to a stop, was with two other riders incase of such an event, so they went back for the pickup, and when I got home I popped the valve cap covers and tried spinning the crank in reverse to see if the cam chain was the culprit, but it held, and then I discovered that the #1 intake was stuck down, and when I fully removed the plug, she's all mashed in!!!  the only good news is that I didn't find any metal frags in the oil, so there's a very small silver lining in this!!!
Just thought I'd share my misery
Offline Harry
    • CB500F
Re: Maiden voyage, disaster!!
« Reply #1 on: August 03, 2005, 01:27:02 AM »
Jeez, why did that happen, d'you think?
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Offline Raul CB750K1
« Reply #2 on: August 03, 2005, 01:37:45 AM »
That's very unlikely to happen. What can the reason be?
Online Bodi
« Reply #3 on: August 03, 2005, 08:21:44 AM »
Either the guide is undersize and seized or the valve spring retainers failed. Or the clearances were tight and Mr. Piston met Ms. Valve; I've had that happen on a new"hot" cam install when inexperience led me to check valve/piston clearance before setting tappet clearance. On a tight setup only a few thou makes the difference between vrooom and kerrrunch.
Offline CB750R
  • 77 CB750F
« Reply #4 on: August 03, 2005, 08:32:28 AM »
my best guess, is that mr piston met mr valve, cuz mr head was machined, cuz mr dumbass previous owner took a wire brush to remove the old head gasket, and pooched the head,
Offline Lumbee
    • My pics...
« Reply #5 on: August 03, 2005, 08:38:52 AM »
...I rebuilt a donor motor I got this past spring, and it had a bent valve exhaust valve.  It was only bent slightly, and not enough to damage the piston.  I am assuming it made contact with the piston, or how else would it have become bent?  Anyway, it happens...
"I'm not a welder, but I play one on HondaChopper.com"
Offline Philly550K1
« Reply #6 on: August 03, 2005, 11:18:40 AM »
was the spark plug mashed?
Offline Lumbee
    • My pics...
« Reply #7 on: August 03, 2005, 12:09:08 PM »
...I don't think so..however, now that you mention it the #3 plug (which was the damaged vavle) was kind of hard to screw in..but how would the valve hit the plug?  As I said it was only a slight bend in the valve...enough that it was not sealing...
Offline Trevor from Warragul
« Reply #8 on: August 04, 2005, 12:50:30 AM »
I had this happen to me THREE times!  Turned out to be crap case-hardening on the valve retainers!  Got the ones I had nitrided and the problem went away.
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline CB750R
  • 77 CB750F
« Reply #9 on: August 04, 2005, 08:25:27 AM »
haven't had the extra body to lift the engine outa the frame, yet so I haven't been able to diagnose the failure, but that one is interesting to look out for, thanks.
Offline nomadwarmachine
  • 1972 CB750K2, 1974 Norton Commando 850 Mk2
    • Nomadwarmachine.com
« Reply #10 on: August 04, 2005, 09:51:26 AM »
Would love to see some photos of the problem, once you get the engine out. Hope that the problem is nothing major and you are back on the road soon!!
Offline CB750R
  • 77 CB750F
« Reply #11 on: August 04, 2005, 01:20:40 PM »
Will definatly post some pics of the carnage, not only for the gore factor, but hopefully to gleen some input from all of you, I think the engines' commin out this weekend, if I can muster up a sucker (um er friend, I mean) to help me lift it onto my bench
hehee
