Author Topic: cb350f carb rebuild or replace question  (Read 3291 times)
monknomo
« on: February 20, 2008, 07:36:52 PM »
So, I was rebuilding my carbs and when I pulled them apart one of them looked like this :o :
I've never seen a carb that pitted and am leaning toward replacement.  Just for kicks, I thought I'd ask whether or not y'all thought it is rehabilitate-able.
Also, any suggestions on finding new carbs (other than playing at being a vulture on ebay)?
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: cb350f carb rebuild or replace question
« Reply #1 on: February 20, 2008, 08:06:22 PM »
 :o
The best thing to do with that carb is take a hammer and nail and drive the nail into your shop wall and hang the carb on it.........that's wild  :o
You can post on this forum for parts wanted, someone here likely has one or two...
but I'd say that carb is no longer any good.
 Matt.
Gallery at:
monknomo
« Reply #2 on: February 20, 2008, 08:37:39 PM »
Yeah, I figured it was pretty much spent, but I always like to check to see if someone has a clever idea.  Plus engine-death porn is always fun to see.  I'm actually a little surprised to see it this bad, because it wasn't running that rough, just getting awful mileage.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: February 20, 2008, 08:41:34 PM »
You know, I've seen some bad ones too... but on old tractors and they're cast steel. The problem is if it's that bad, there's a good chance that there are some air leaks somewhere that could cause a lean condition....
You could give it a shot? put it together and try it. but I recommend a new carb.
 Matt.
Gallery at:
Offline mark
« Reply #4 on: February 20, 2008, 08:50:53 PM »
That one looks like it has rotted even beyond the 'interesting experiment' point.
Yeah, it could run, but not like some better examples would.
A decent rack of used carbs seems to cost less than the gasket kits anyway...
Happy trails.
F you mark...... F you.
Offline Godffery
  • Godffery's Garage
« Reply #5 on: February 20, 2008, 11:12:48 PM »
I would have to say it's not worth trying to save, and I've even saved crap like this :
 http://springvinmoto.com/gallery/album351
But I did end up replacing 2 out of 4 body's !
If your interested, I may have a good replacement one for you.
jstephens7@wi.rr.com
Godffery
http://tinyurl.com/yoelqb
Offline Jay B
« Reply #6 on: February 21, 2008, 04:53:56 AM »
My CB175 had one carb eaten away like that, the other was perfect. Can't figure out why one and not the other.  I've got a junk rack of carbs if you want to replace that carb body.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
