Author Topic: my pecock is leaking all over the place.  (Read 1823 times)
e_b_c
« on: August 05, 2005, 11:48:06 AM »
i know. ...what am i, 12?
The threaded bowl on the bottom of my petcock on my 72 cb350f has sprung a leak.
My question is: Is this a common size that i can pick up from any bike of this era? Or can i seal it with tank sealer?
Thanks for any inforamtion. i'm going to go try and grow-up.
e_b_c
Offline Chris Liston
    • http://christopherliston.com
Re: my pecock is leaking all over the place.
« Reply #1 on: August 05, 2005, 12:01:24 PM »
First you must learn control :)
Seriously,  you should try and take it apart.  The orings are probably shot and thats why it may be leaking.  I repaired my 76' 550 Petcock last year with a new oring from the hardware store.  Good as new, total cost 58cents.   I'm not saying that is your issue and I'm not familiar with what a 72 CB350F petcock looks like.  But if it's leaking it probably wouldn't hurt to take it apart and see whats going on in there.  Is it leaking from the front, where the turn mechanism is or flowing down from where it mounts to the tank?
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
e_b_c
« Reply #2 on: August 05, 2005, 12:14:55 PM »
I'm sorry, let me clarify. i was too busy laughing at myself.
I have identified that the leak is coming from a pinhole that is actually in the "bowl" part of the petcock. I was checking most of the other obvious places that it may be leaking (anywhere it connects to another part) when the little jerk started spouting a STEADY stream of fuel from the side of that bowl. I took it off and sure enough the inside looks like hell.
does anyone know if these were standard parts or will i have to find a petcock that was specific to that tank?
e
Offline Philly550K1
« Reply #3 on: August 05, 2005, 12:18:47 PM »
he said,   mm-hmm....  he said....   mmm-hmm-hmmm.   he ss-ssaid...
sounds like a job for JB Weld, while you're looking.....
-beavis.  i mean, the great cornholio.
Offline Chris Schneiter
    • Christopher Schneiter Photographer
« Reply #4 on: August 05, 2005, 01:57:46 PM »
But seriously..I snapped off my standtube last year, so I decided to just replace the whole standtube/petcock unit....supposedly, according to the parts guy, it was one of the last 35 in existence! (I'm not sure if I believe him)...the whole unit cost me 70 bucks, but I decided to go new because of how the old one looked. I got mine (OEM) through the Honda dealer.
CB750 K6
Offline nomadwarmachine
  • 1972 CB750K2, 1974 Norton Commando 850 Mk2
    • Nomadwarmachine.com
« Reply #5 on: August 05, 2005, 03:02:03 PM »
If you just have a pinhole in the bowl, I would drain the tank, remove the petcock, patch with JB Weld and ride.  While you're at it, you should also go ahead and replace the O-Ring -- cheap insurance!
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #6 on: August 05, 2005, 03:44:18 PM »
I had the same problem.  Easy fix is a new O-ring and JB weld for the pin hole. hasn't leaked since.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
whoismattclark
« Reply #7 on: April 11, 2006, 11:22:23 PM »
Anyone know the size of the O-ring that goes in the petcock's fixing nut to meet the tank.  I was hoping to head to the hardware store tomorrow (I finally saved up my 58¢), but won't have access to my bike to pull the petcock.  And, what material should I be looking for that is gas resistant?
thanks...
MDC
« Reply #8 on: April 12, 2006, 05:36:10 AM »
Basically they'll probably have a drawer of orings.  I just brought my old dried out oring to the store and matched it up.  Best way is to bring the old one.  Sorry can't be of more help.
